Post by donkeychomp on Apr 18, 2018 23:14:02 GMT 1
Snapped one dammit. Anyone know who sells them?
Post by JonW on Apr 19, 2018 0:09:00 GMT 1
yuniparts on ebay. xt500 is same.
Post by earthman on Apr 19, 2018 7:52:18 GMT 1
Snapped one dammit. Anyone know who sells them? Alex Did it snap whilst you were trying to remove it from it's pivot point or near the tip whilst trying to flex it up and over the stop/resting pin? Anyone got any top tips on how to this and keep the needle intact? I know that Dusty has used a pair of scissors around the pivot to aid removal for example.
Post by midlifecrisisrd on Apr 19, 2018 8:13:44 GMT 1
I use a pair of teaspoons
Clamp speedo in a vice (by the drive so you don't crush anything)
Turn the needle to 60mph then put a spoon in either side so spoon backs are supported by the face screws and the tips are under the needle
Push down on the spoon handles while a second person holds a large clear food bag over the face
Pick broken needle out of bag and buy a new one lol
Seriously if it brakes don't worry, if it's that brittle I'd rather it broke at that point and not on a pothole
Post by donkeychomp on Apr 19, 2018 10:42:07 GMT 1
Thanks Jon I'll have a look.
Earthman no..I got it off fine using 2 screwdrivers, it snapped as I was masking the black round bit off! (it needed paint)
Post by JonW on Apr 19, 2018 11:09:38 GMT 1
I Pick broken needle out of bag and buy a new one lol Steve Too funny... but soo true.
Post by earthman on Apr 19, 2018 11:17:16 GMT 1
I use a pair of teaspoons Clamp speedo in a vice (by the drive so you don't crush anything) Turn the needle to 60mph then put a spoon in either side so spoon backs are supported by the face screws and the tips are under the needle Push down on the spoon handles while a second person holds a large clear food bag over the face Pick broken needle out of bag and buy a new one lol Seriously if it brakes don't worry, if it's that brittle I'd rather it broke at that point and not on a pothole Steve Why 60mph rather than lifting the needle over it's stop? And when you come to put it back on, what are you aligning it??
Post by Jethro5 on Apr 19, 2018 12:10:10 GMT 1
Buy two and replace both. Then you will not have one looking faded.
Post by JonW on Apr 19, 2018 13:34:41 GMT 1
Ive just done a set today. I did both and repainted the temp to get a match as close as poss with the paint I had here. And yes I did have to go back and remove the oil round the screw head that had come up teh thread from the cleaning of the mech earlier in the day. more work lol
Post by earthman on Apr 19, 2018 13:48:56 GMT 1
Nice work, did you wind the mileage back to 71?
Post by midlifecrisisrd on Apr 19, 2018 13:52:22 GMT 1
I use a pair of teaspoons Clamp speedo in a vice (by the drive so you don't crush anything) Turn the needle to 60mph then put a spoon in either side so spoon backs are supported by the face screws and the tips are under the needle Push down on the spoon handles while a second person holds a large clear food bag over the face Pick broken needle out of bag and buy a new one lol Seriously if it brakes don't worry, if it's that brittle I'd rather it broke at that point and not on a pothole Steve Why 60mph rather than lifting the needle over it's stop? And when you come to put it back on, what are you aligning it?? 60 mph as it is centre Can't lift the needle over the stop if the stop is the metal type as risks needle snapping Personally I mark the mechanism underneath so I know where 60 mph is when putting the needle back on I use 60 rather that zero as some kph to mph decals have a slightly different stop position Also always check with my drill Hi speed = 38mph Steve
Post by earthman on Apr 19, 2018 14:02:17 GMT 1
Why 60mph rather than lifting the needle over it's stop? And when you come to put it back on, what are you aligning it?? 60 mph as it is centre Can't lift the needle over the stop if the stop is the metal type as risks needle snapping Personally I mark the mechanism underneath so I know where 60 mph is when putting the needle back on I use 60 rather that zero as some kph to mph decals have a slightly different stop position Also always check with my drill Hi speed = 38mph Steve I didn't know that there were two different types of stop in the first place. I like your 60 idea but don't really understand how you rotate the pivot/spindle to that position before pushing the needle back on??
Post by midlifecrisisrd on Apr 19, 2018 14:38:12 GMT 1
60 mph as it is centre Can't lift the needle over the stop if the stop is the metal type as risks needle snapping Personally I mark the mechanism underneath so I know where 60 mph is when putting the needle back on I use 60 rather that zero as some kph to mph decals have a slightly different stop position Also always check with my drill Hi speed = 38mph Steve I didn't know that there were two different types of stop in the first place. I like your 60 idea but don't really understand how you rotate the pivot/spindle to that position before pushing the needle back on?? If you look at the mechanism underneath there is a dome shaped section on the needle shaft that the magnet spins in. You can carefully rotate this to move the needle shaft. It is also where I put alignment marks for 60mph before I remove the needle Steve
Post by gci_scot on Apr 19, 2018 17:39:56 GMT 1
I bought these . eBay item 232536666846
Post by donkeychomp on Apr 19, 2018 20:51:36 GMT 1
Spent about 20 mins on his eBay shop and failed to find those! Thanks Scot, I ordered a pair.
Post by earthman on Apr 19, 2018 20:58:39 GMT 1
I didn't know that there were two different types of stop in the first place. I like your 60 idea but don't really understand how you rotate the pivot/spindle to that position before pushing the needle back on?? If you look at the mechanism underneath there is a dome shaped section on the needle shaft that the magnet spins in. You can carefully rotate this to move the needle shaft. It is also where I put alignment marks for 60mph before I remove the needle Steve Ah, thanks Steve, all is clear now.
Post by bezzer on Apr 19, 2018 22:35:52 GMT 1
Ive just done a set today. I did both and repainted the temp to get a match as close as poss with the paint I had here. And yes I did have to go back and remove the oil round the screw head that had come up teh thread from the cleaning of the mech earlier in the day. more work lol Jon, Can I ask which paint you used on your needle refurb?, I bought one of those humbrol enamel model paints recently, but on reflection I thinks it’s too dark a shade of orange!
Post by JonW on Apr 19, 2018 22:54:44 GMT 1
Nice work, did you wind the mileage back to 71? Yes, I could have done the 10's reel but was over it by then and I can rack up 70kms pretty quickly so didnt bother. The speedo didnt come with this bike and its a full resto, we dont have old MOTs of anything like that here and I certainly didnt have any with this bike, I bought it as a frame only and the speedo came from a mate, so not bothered about keeping the milage etc. Ive just done a set today. I did both and repainted the temp to get a match as close as poss with the paint I had here. And yes I did have to go back and remove the oil round the screw head that had come up teh thread from the cleaning of the mech earlier in the day. more work lol Jon, Can I ask which paint you used on your needle refurb?, I bought one of those humbrol enamel model paints recently, but on reflection I thinks it’s too dark a shade of orange! I actually used a mixture of paints, some high vis dayglo orange and a bit of yellow and some black and red from my stash of colours here. Its not quite as perfect as it looks in this pic as the flash has toned it down a bit, but its certainly much better than just the dayglo stuff which was very bright. Ive seen NOS ones with dayglo, so thats what they probably were tho, sadly skills plus doesnt show what that bike had, unless Ive missed it.
Post by donkeychomp on Apr 19, 2018 23:52:33 GMT 1
I used the gf's nail varnish on the temp needle. Perfect match lol.
ps it dries VERY quickly in this heat so do it once and fast
Post by JonW on Apr 20, 2018 6:33:28 GMT 1
heat? in the UK? Er...
Post by bezzer on Apr 20, 2018 7:58:13 GMT 1
“I actually used a mixture of paints, some high vis dayglo orange and a bit of yellow and some black and red from my stash of colours here. Its not quite as perfect as it looks in this pic as the flash has toned it down a bit, but its certainly much better than just the dayglo stuff which was very bright. Ive seen NOS ones with dayglo, so thats what they probably were tho, sadly skills plus doesnt show what that bike had, unless Ive missed it.”
Damn, I thought you were about to reveal the magic formula then Jon!! 🤣🤣🤣
Post by JonW on Apr 20, 2018 8:01:28 GMT 1
haha, if i had it you know I would mate.
Post by donkeychomp on Apr 20, 2018 12:20:13 GMT 1
Was boiling here yesterday, 29c. Same weather today!
Post by wangwang on Apr 20, 2018 12:51:50 GMT 1
You can get the needle past the stop ok if you don't push it fully home until it's past the stop.
Post by JonW on Apr 20, 2018 13:14:29 GMT 1
You can get the needle past the stop ok if you don't push it fully home until it's past the stop. Thats what I do too.
Post by JonW on Apr 20, 2018 13:15:17 GMT 1
Was boiling here yesterday, 29c. Same weather today! Alex Same as here last week, tho our summer is finally ending I think... soon be jeans weather, ie under 20.
Post by earthman on Apr 20, 2018 16:08:41 GMT 1
You can get the needle past the stop ok if you don't push it fully home until it's past the stop. So I guess that you try and prise the old/current needle up a bit before lifting it over the stop pin.
Post by wangwang on Apr 20, 2018 18:18:03 GMT 1
You can get the needle past the stop ok if you don't push it fully home until it's past the stop. So I guess that you try and prise the old/current needle up a bit before lifting it over the stop pin. Sorry, I meant when replacing the needle, you can turn it on the pin from about 7 o'clock on the dial, take it over the stop then push into place.
Post by JonW on Apr 20, 2018 23:07:36 GMT 1
If you buy the dials, just buy the ebay XT needles... you will need them. the old needles have seen too much sun and are brittle anyway.
Post by markhoopy on Apr 20, 2018 23:26:44 GMT 1
