Post by russpuss on Jun 2, 2020 20:08:00 GMT 1
Post by oldbritguy on Jun 2, 2020 21:59:39 GMT 1
That looks lovely. Will look even better fitted on the bike.
Every time I think this is on its final leg, more magic happens.
Great stuff Russ
John🙂
Post by JonW on Jun 3, 2020 3:21:42 GMT 1
Ive seen a few people polish these and always wondered how well they fit in the yokes after as the OEM finish is ridged which not only helps grip the triples but means they are also a bit fatter. Interested to hear your thoughts.
Post by russpuss on Jun 3, 2020 4:06:20 GMT 1
Ive seen a few people polish these and always wondered how well they fit in the yokes after as the OEM finish is ridged which not only helps grip the triples but means they are also a bit fatter. Interested to hear your thoughts. I’ve had a thou or 2 of to rid the scratches but the trees will be powdercoated to make the difference up, time will tell.
Post by dusty350 on Jun 3, 2020 7:26:02 GMT 1
Forks look great I've polished a few now and never had an issue with the yokes gripping the forks, but I've never gone mad with the polishing, so it's only a minute amount we are talking about. Personally, I wouldn't powdercoat the inside face of the yokes to make up any difference. You are asking a coat of paint to become your mating surface between yoke and fork leg - better off getting masked and left bare metal. It will pinch up tighter that way, and not be affected by the paint/powder compressing down. Dusty
Post by russpuss on Jun 3, 2020 14:56:56 GMT 1
Post by 3tj6 on Jun 3, 2020 18:24:46 GMT 1
Refurbed back caliper sorted like the powder coating who has done it ? Is it local to chesterfield
Post by russpuss on Jun 3, 2020 18:25:24 GMT 1
Refurbed back caliper sorted like the powder coating who has done it ? Is it local to chesterfield Long Eaton
Post by russpuss on Jun 4, 2020 15:44:44 GMT 1
Fully rebuilt what a pig of a job
Post by dusty350 on Jun 4, 2020 18:54:33 GMT 1
Post by russpuss on Jun 7, 2020 20:07:41 GMT 1
Had an hour and started the undertray Exhaust man used the same holes I need so need some longer studded vibration bolts. Wants trimming and bending near the swingarm and 2 tabs welding on to the frame, maybe 4 to tighten it all up to.
Post by oldbritguy on Jun 7, 2020 23:21:46 GMT 1
Looking good Russ
Nice n tidy
Post by fatfreddy on Jun 15, 2020 21:38:59 GMT 1
Looks great!
fabiostar
the older i get the faster i was.
Post by fabiostar on Jun 15, 2020 22:32:15 GMT 1
What a brilliant read that was.
Post by flames on Jun 16, 2020 17:49:08 GMT 1
What an amazing job you are doing and an absolutely fantastic read. I was hooked from the off.......I did a search for 'the riddler' but nothing comes up. Did u do a thread on the build? Would like to have a read through that aswell.
Post by russpuss on Jun 16, 2020 17:51:43 GMT 1
What an amazing job you are doing and an absolutely fantastic read. I was hooked from the off.......I did a search for 'the riddler' but nothing comes up. Did u do a thread on the build? Would like to have a read through that aswell. rdlccrazy.proboards.com/thread/36042
Post by flames on Jun 16, 2020 18:16:13 GMT 1
What an amazing job you are doing and an absolutely fantastic read. I was hooked from the off.......I did a search for 'the riddler' but nothing comes up. Did u do a thread on the build? Would like to have a read through that aswell. rdlccrazy.proboards.com/thread/36042Thank you. That will be why the riddler didnt give me any results.
Post by russpuss on Jul 1, 2020 20:37:32 GMT 1
And she’s off to the welders for some tabs for the undertray to be finished, headlight brackets being made in billet so she’s almost ready for a tear down and the real build to start. Still waiting for a billet clutch case that runs pump with see through cover and lock up clutch, but believe it’s not far off being ready.
Post by flames on Jul 1, 2020 21:02:57 GMT 1
Whoop whoop!!! Can't wait to see the final build and more importantly, the finished article.
Post by russpuss on Jul 3, 2020 19:52:42 GMT 1
Post by flames on Jul 3, 2020 20:01:55 GMT 1
Wow!!!
Post by russpuss on Jul 7, 2020 20:29:54 GMT 1
Well Bri didn’t like my attempt at a rear master cylinder bracket so whilst he’s had the bike on the ramp he’s making another, well, he’s already on Mk2. See pics, he’s moved it all in toward the frame, it needs a rose joint instead he says. Mk2
Post by russpuss on Jul 8, 2020 19:45:51 GMT 1
Here we go, had an hour watching Bri finish this whilst I drank his beer! No milling machine in the man cave The main man himself Hand made 1 off, good lad is Bri.
2taol
Post by 2taol on Jul 8, 2020 22:03:26 GMT 1
nicely done, looks well suited to the yoshimura !
Post by JonW on Jul 10, 2020 14:34:19 GMT 1
Nice work. Not everyone has a lathe and a mill and defo not a CNC version. Bloke does nice work.
Post by dusty350 on Jul 10, 2020 21:33:50 GMT 1
And he's doing it with his eyes shut !! Genius Looking good Russ Love those little detail parts. Dusty
Post by jon on Jul 11, 2020 10:05:40 GMT 1
And he's doing it with his eyes shut !! Genius Looking good Russ Love those little detail parts. Dusty If you took the tools away it looks to me like he’s doing tai chi Jon
Post by russpuss on Jul 13, 2020 16:09:52 GMT 1
Handlebars and levers came so I can now measure for HEL cables. The black bits won’t be black when finished.
Post by russpuss on Jul 13, 2020 21:01:03 GMT 1
Bought a 6mm rose joint and tapped the thread to 8mm Test fit Now to turn up a spacer to replace the washers
Post by russpuss on Jul 13, 2020 21:59:02 GMT 1
Made the spacer Then found it would hit the swinger 🤨 Plan b use old part to space temporarily Add washers for spacing to see what’s what That should work, so 3 spacers required to fit it
