Post by russpuss on Feb 4, 2020 14:57:44 GMT 1
Released some of my equity into Norbo’s sky rocket
Post by russpuss on Feb 8, 2020 22:56:36 GMT 1
1 step forward, 2 back
Post by veg on Feb 9, 2020 11:14:20 GMT 1
Awesome 😎
Post by Tobyjugs on Feb 9, 2020 21:08:14 GMT 1
Post by donkeychomp on Feb 10, 2020 0:09:26 GMT 1
Your bike your choices but bleedin' eck those pipes look so cool...top work matey.
Post by russpuss on Feb 10, 2020 0:13:14 GMT 1
Your bike your choices but bleedin' eck those pipes look so cool...top work matey. Alex Trying to top the riddler
Post by veg on Feb 10, 2020 0:15:04 GMT 1
Not trying Russ definitely topping.
Post by dusty350 on Feb 10, 2020 8:05:39 GMT 1
I love the pipe exit under the seat cowl Looks awesome ! Twin shocks look great too Dusty
Post by russpuss on Apr 18, 2020 13:40:54 GMT 1
So not touched for ages, and only ever started with a frame, in lockdown so been of faceache all day everyday to stay in touch, low and behold this loom turns up with switchgear for £40 posted, well to say I’m happy is an understatement. Had a few texts with Mutts as I’ve got the iggy and pd that he wired up so I know (fingers crossed) what to do to get it wired up. Hopefully then I can get the brakes done and start stripping to get some colours on it.
Post by russpuss on Apr 19, 2020 9:03:01 GMT 1
Post by russpuss on May 1, 2020 23:00:14 GMT 1
Quick update, 3 hours splitting the Canadian loom today, made a sub loom to change the handlebar controls to uk spec. All the wiring sorted now. Was a bugger to get it all to work how it should but worth the hassle.
Post by loctite on May 2, 2020 16:16:49 GMT 1
Russ now you’ve sorted the loom can you advise how to do it I have one to do,cheers 😀
Post by russpuss on May 2, 2020 16:21:58 GMT 1
Russ now you’ve sorted the loom can you advise how to do it I have one to do,cheers 😀 The only problem I’ve encountered so far is I’ve split the live to the clocks and rear light and main beam to 1 wire so the fuse for the tail is now defunct. It’s pretty easy but I’m using non standard lights etc.
Post by russpuss on May 4, 2020 20:05:20 GMT 1
Not a biggy as been tidying cave to get this benched up. Cut the helmet lock off so seat now fits as shock got in way. Hopefully in the cave a bit longer tomorrow. I’ll shape it more to surround the shock before it gets painted.
lcfc
Post by lcfc on May 4, 2020 20:56:52 GMT 1
Absolutely brilliant build I have enjoyed reading through this, the pipes are outstanding excellent work.
Post by russpuss on May 10, 2020 15:09:19 GMT 1
Post by russpuss on May 10, 2020 17:06:52 GMT 1
Mocked plate up, think I’ll cut the subframe bracket off and have some tabs welded on to make the plate sit back a bit.
Post by russpuss on May 15, 2020 21:07:36 GMT 1
So the gsxr forks needed chroming, dropped on these rgv ones that didn’t. The outers were a bit scabby so had a thou or too whipped off to make them smooth again. Was going to do them white but seen someone doing that and I’m not 1 to copy so having eyed them up with the painted muddy I think I’m going mirror polished instead.
Post by russpuss on May 19, 2020 16:32:31 GMT 1
Cut all the rubbish off the rear subframe had to improvise outside as too hot in the cave Off to see Bri now to weld a bracket on for the new rear light and number plate so it sits back a bit
Post by russpuss on May 19, 2020 16:49:28 GMT 1
Just a quick mock up to see where it’s going
Post by midlifecrisisrd on May 19, 2020 16:53:14 GMT 1
Never seen such a good use of a sponge scourer 🤣
Post by russpuss on May 19, 2020 17:28:45 GMT 1
Never seen such a good use of a sponge scourer 🤣 Steve Hope the mrs can get it clean again when I’ve thrown it back in her sink!
Post by russpuss on May 19, 2020 18:49:37 GMT 1
Post by russpuss on May 19, 2020 19:34:30 GMT 1
Little job off the list, getting there now with the dry build. Next sort the brakes out.
Post by russpuss on May 27, 2020 12:42:28 GMT 1
Bit of bling Ken’s
Post by russpuss on May 27, 2020 15:28:40 GMT 1
Refurbed back caliper sorted
Post by russpuss on May 28, 2020 22:20:58 GMT 1
Had a play at making a rear master cylinder bracket, needs tilting forward to allow more piston movement, would prefer one made of billet but not sure on costs
Post by veg on May 28, 2020 22:52:14 GMT 1
Oh me likey, shame the plate isn't EVL 666, and you've got a small black working c**ker cute same as one of my dogs
Post by russpuss on May 29, 2020 15:15:28 GMT 1
Oh me likey, shame the plate isn't EVL 666, and you've got a small black working c**ker cute same as one of my dogs That’s my mate Bri’s dog, I’ve 2 labs and a golden retriever
Post by russpuss on May 29, 2020 15:22:20 GMT 1
Reshaped the rear master cylinder and test fitted the panels and grab rail to make sure lined up around the cut seat bracket
