Post by ppaauull0 on Feb 18, 2018 18:29:59 GMT 1
What gearbox oil are you guys using these days, its for a 31k ypvs. there is so much choice, wondering if there is a favourite.
Post by bezzer on Feb 18, 2018 20:44:44 GMT 1
Just started using Millers GL4 spec, seems good so far on a rebuilt 4L1 motor. However this is such a subjective / emotive subject you will be inundated with others that will have differing opinions - then make your choice!
Post by arrow on Feb 18, 2018 21:19:37 GMT 1
I'm with bezzer on this one. I used a GL4 spec 75/80 gear oil. GL4 is wet clutch compatible. Gear oils are classified differently to engine oils. The 75/80 is approx the same 'weight' as a 10/40 engine oil.
Post by rigga on Feb 18, 2018 21:51:46 GMT 1
ATF
But yes a multitude of opinions on this subject
Post by earthman on Feb 18, 2018 22:44:49 GMT 1
The Haynes manual for my 4LO states 10W/30 engine oil,.....I wonder if they would suggest anything different if the LC had been invented today.
Post by bare on Feb 19, 2018 19:50:45 GMT 1
Have used Yamalube and quickly removed it. ATF has long term issues with non BBearinged spining bits. Your bike.. your choice.
Post by earthman on Feb 19, 2018 21:10:01 GMT 1
Have used Yamalube and quickly removed it. ATF has long term issues with non BBearinged spining bits. Your bike.. your choice. Sorry, what are these long term issues??
Post by simon998 on Feb 20, 2018 11:12:35 GMT 1
Isn't Silkoline Light Gear Oil still to go to?
Post by ppaauull0 on Feb 21, 2018 18:23:14 GMT 1
What grade is the best to use?
Post by earthman on Feb 21, 2018 21:53:25 GMT 1
What grade is the best to use? I wonder what the likes of Stan Stevens would say.
Post by bezzer on Feb 21, 2018 21:56:35 GMT 1
What grade is the best to use? 75/80 in my case, just make sure it’s GL4 spec or higher.
Post by alistair64 on Feb 21, 2018 22:02:32 GMT 1
Isn't Silkoline Light Gear Oil still to go to? Blimey, used that 30 years ago and was supposedly the best oil around then. Is there nothing 'better' after all this time? By 'better', I suppose I mean slick gear changes and excellent protection against wear (although how anyone would know this is very difficult to say).
Post by bezzer on Feb 21, 2018 22:20:44 GMT 1
I doubt oil companies would spend the money on development testing oils for small capacity two strokes anymore. There can’t be enough demand for it, most motocrossers are 4 strokes now. Probably why the ‘best stuff’ years ago, is still the ‘best stuff’ now!, imho of course.
Post by arrow on Feb 21, 2018 23:02:31 GMT 1
The best gear changes I had was with the 75/80 oil.
Post by sp885 on Feb 22, 2018 9:14:59 GMT 1
I use Motul Transoil 10/30 👍
antos
Post by antos on Feb 23, 2018 6:58:40 GMT 1
Silkolene light for me no complaints at all👍
Post by budgie on Feb 23, 2018 8:08:39 GMT 1
Silkolene light for me no complaints at all👍 +1 never an issue.....👍
Post by beardy on Feb 23, 2018 8:20:32 GMT 1
What grade is the best to use? 75/80 in my case, just make sure it’s GL4 spec or higher. when i saw this thread i was determined not to have any input because on virtually every car/motorbike forum i`ve been on there are always discussions on oil with nothing conclusive. unfortunately curiosity got the better of me. anyway, my point. on a land rover forum i read that gl5 oil can damage phosphor bronze bushes and slip rings with prolonged use. i don`t know if this is applicable to lc`s but it may be that was what `bare` was alluding too. apologies for confusing the issue further (:
Post by earthman on Feb 23, 2018 9:31:04 GMT 1
75/80 in my case, just make sure it’s GL4 spec or higher. when i saw this thread i was determined not to have any input because on virtually every car/motorbike forum i`ve been on there are always discussions on oil with nothing conclusive. unfortunately curiosity got the better of me. anyway, my point. on a land rover forum i read that gl5 oil can damage phosphor bronze bushes and slip rings with prolonged use. i don`t know if this is applicable to lc`s but it may be that was what `bare` was alluding too. apologies for confusing the issue further (: Thanks for your input, personally I have no idea if it could damage phosphor bronze,......can someone point us to some proof/results from lab testing, that may clear this up at once and for all??
Post by Tobyjugs on Feb 23, 2018 15:43:32 GMT 1
when i saw this thread i was determined not to have any input because on virtually every car/motorbike forum i`ve been on there are always discussions on oil with nothing conclusive. unfortunately curiosity got the better of me. anyway, my point. on a land rover forum i read that gl5 oil can damage phosphor bronze bushes and slip rings with prolonged use. i don`t know if this is applicable to lc`s but it may be that was what `bare` was alluding too. apologies for confusing the issue further (: Thanks for your input, personally I have no idea if it could damage phosphor bronze,......can someone point us to some proof/results from lab testing, that may clear this up at once and for all?? If i understand it cortectly it's all to do with the sulphur content GL4 is safe GL5 not safe
Post by 84rzrider on Mar 8, 2018 4:03:46 GMT 1
I use Lucas 80/90 in all my two stroke gearboxes for years and thousands of hard street miles with excellent results.
Post by bare on Mar 8, 2018 4:38:56 GMT 1
Surprised that even this arena has sunk to 'oil wars' Usually it's confined to the Crap cars (where the meanest, most worthless, pile of Shite.. recently aquired tho) Clearly demands THE most esoteric/pricey/heavily advertised oils. Because it will make the POS perform better than new.. as if.
Post by ypvs400 on Mar 8, 2018 7:54:35 GMT 1
ATF every time .
Post by ganzeeguy on Mar 8, 2018 20:57:42 GMT 1
+1 to bare
Post by copper99 on Mar 9, 2018 15:24:38 GMT 1
.... wondering if there is a favourite. ...everyone has a favourite oil and will put a case forward for it! Oil and fuel threads are always a great(and regular) debate here! While I do get a specific gear oil, my favourite is the one I can pick up off the shelf easily, in all honesty, the boxes dont seem to be that fussy, I just change it once a year ...We certainly chucked what ever was around in them back in the day and I dont remember anyone changing it unless it was in bits anyway!
Post by earthman on Mar 9, 2018 17:08:40 GMT 1
.... wondering if there is a favourite. ...everyone has a favourite oil and will put a case forward for it! Oil and fuel threads are always a great(and regular) debate here! While I do get a specific gear oil, my favourite is the one I can pick up off the shelf easily, in all honesty, the boxes dont seem to be that fussy, I just change it once a year ...We certainly chucked what ever was around in them back in the day and I dont remember anyone changing it unless it was in bits anyway! Which one is most likely to be in the stores/on the shelf around your way then? Generally I avoid Halfords for anything if I can, sadly they have put a lot of little shops out of business a long time ago.
Post by jon on Mar 9, 2018 20:12:46 GMT 1
...everyone has a favourite oil and will put a case forward for it! Oil and fuel threads are always a great(and regular) debate here! While I do get a specific gear oil, my favourite is the one I can pick up off the shelf easily, in all honesty, the boxes dont seem to be that fussy, I just change it once a year ...We certainly chucked what ever was around in them back in the day and I dont remember anyone changing it unless it was in bits anyway! Which one is most likely to be in the stores/on the shelf around your way then? Generally I avoid Halfords for anything if I can, sadly they have put a lot of little shops out of business a long time ago. I’m going to be using this in my budget YPVS: www.wilko.com/car-maintenance-products/comma-gear-oil-ep80w-90-gl4-1l/invt/0077164As bare says snobbery using the most expensive oil (possibly on a clapped out engine) is not going to make it brand new. The oil grade standards have improved over the years, and even a budget oil (like this) is better than some from the past. Cheap enough to change regularly (which is probably more important). Available off the shelf easily across the country. Jon
Post by hampo on Mar 9, 2018 20:34:55 GMT 1
Jon, I would be wary of using any EP oil in a bike that uses the gearbox oil to lube the clutch. As I understand it they are formulated for the Extreme Pressures between gears and will cause incurable clutch slip. This lore dates back to my British bike days and things may of course have changed. If not, most economy engine oils will be ok, my valve has done 45k miles in my ownership without dedicated gear oil and I've never had any box or clutch problems. Yamaha boxes are well made and robust.
Post by copper99 on Mar 9, 2018 21:39:39 GMT 1
...everyone has a favourite oil and will put a case forward for it! Oil and fuel threads are always a great(and regular) debate here! While I do get a specific gear oil, my favourite is the one I can pick up off the shelf easily, in all honesty, the boxes dont seem to be that fussy, I just change it once a year ...We certainly chucked what ever was around in them back in the day and I dont remember anyone changing it unless it was in bits anyway! Which one is most likely to be in the stores/on the shelf around your way then? Generally I avoid Halfords for anything if I can, sadly they have put a lot of little shops out of business a long time ago. Most usually Halfords Light gear oil or if I have some left over 10/40 from the 4 strokes and there's enough of it, ill use that.
Post by urbantangleweed on Mar 9, 2018 22:07:29 GMT 1
Light Gear Oil worked great in my KTM200EXC, happy to go that route with the YPVS too.
