Post by iwantalc on May 29, 2015 21:16:05 GMT 1
i want to change the 2 stroke oil in my lc .ypvs engine fitted still running autolube but want the smell of the old castrol r any recomendations and should i completely flush oil out of autolube tank.. is running quiet low on 2stroke at the moment thanks..
Post by neo on May 29, 2015 21:22:43 GMT 1
I am in agreement with the smell, however I have been advised to drop a bit in the tank for the smell as the oil is a bit thick for the auto lube mechanism. I run semi at the moment as I am running in
Post by botty on May 29, 2015 21:27:34 GMT 1
Do not use castrol R in your oil tank.
It is for pre mix usage.
I think it it also not compatible with synthetic oils.
I have seen people drop a cap full of castrol r in the fuel tank to get the smell of the gods. Not sure how safe that is though.
You need to search for castor based oils and do some research
Post by iwantalc on May 29, 2015 21:39:54 GMT 1
is there any other oils that give the same smell but is safe to use in autolube tank ..thanks 4 the above replies ..
Post by neo on May 29, 2015 22:00:47 GMT 1
I follow a mate who uses castrol racing 2t (I think) fully synthetic and it smells lovely
Post by li150ss on May 30, 2015 10:45:14 GMT 1
I follow a mate who uses castrol racing 2t (I think) fully synthetic and it smells lovely does he premix it or autolube
Post by markhoopy on May 30, 2015 13:59:04 GMT 1
They stopped making Castrol R a long time ago. The equivalent is Power 1 Racing 2T - you can use it with the autolube system and it smells quite lovely
castrol r
May 30, 2015 18:22:57 GMT 1
via mobile
Post by Delbert on May 30, 2015 18:22:57 GMT 1
They stopped making Castrol R a long time ago. The equivalent is Power 1 Racing 2T - you can use it with the autolube system and it smells quite lovely I think it was castrol a747 peeps were using as premix or dropping a tad in the tank ,,, the power 1 sounds interesting if its fit for autoloube
big g
midlife crisis
Post by big g on May 31, 2015 8:10:31 GMT 1
i have been useing castrol racing 2t for about a year now in my autolube,it smells nice but not the castrol 'R' smell we all love.
Post by ashtons99 on May 31, 2015 15:03:06 GMT 1
I just put equivalent of a spoonful of castrol R in my tank, you don't need much to get the smell. An old lad near me gives me it, I think he bought loads when they stopped making it
Post by arrow on May 31, 2015 17:11:29 GMT 1
Castrol R is a castor based oil. Rockoil do one and also Morris's of Shrewsbury make one as well. There will be others too.
castrol r
May 31, 2015 20:31:07 GMT 1
via mobile
Post by yazza54 on May 31, 2015 20:31:07 GMT 1
Must admit I was disappointed when I fired mine up on the motorex semi synth i bought, barely smells of anything!!
Post by majortom on May 31, 2015 23:09:02 GMT 1
Morris oil do a replacement it smells exactly the same, i sill wouldn't use it with semi or fully synthetic
i do use it in my hedge cutter - my hedges are the best kept in the village
i will look it out and post the name of it
Post by steve h on May 31, 2015 23:26:49 GMT 1
I don't think it smells the same as it did in the olden days.............. When I was a bin lid, you could smell it on your clothes the day after
The current 2t oil I use smells like fly spray.........
Post by Eyrey1 on May 31, 2015 23:39:22 GMT 1
i use morris castor 2 stroke 5 litres for 45 quid deliverd , castrol 747 , shell racing castor picture of a go cart on the front and a few others , i use them through auto lube and have never had a problem and thats in race rep 250's i get allsorts of wierdo's on big 1000's following me but wont go past me , then at lights they pull up saying fukin hell that smell takes me back
mixing one castor with another is ok but do not mix with any other oils ! if you want to use it empty your tank and start again bleed the whole system
Post by iwantalc on Jun 1, 2015 19:25:35 GMT 1
i use morris castor 2 stroke 5 litres for 45 quid deliverd , castrol 747 , shell racing castor picture of a go cart on the front and a few others , i use them through auto lube and have never had a problem and thats in race rep 250's i get allsorts of wierdo's on big 1000's following me but wont go past me , then at lights they pull up saying fukin hell that smell takes me back mixing one castor with another is ok but do not mix with any other oils ! if you want to use it empty your tank and start again bleed the whole system where can i get this oil and out of the 3 mentioned what would be your preference thanks eyrey1 ..des
Post by 4l04ever on Jun 1, 2015 21:44:43 GMT 1
Castrol A747 is excellent for race two stroke engines, but premix only. Expensive though. Around £15 to £20 per litre.
Post by shandyboy on Jun 1, 2015 23:09:21 GMT 1
When I was a boy i used castor R30 in the autolube with no problems however I used the bike daily,think it would clog up if I used it know as I don't use the bike daily !! however a drop of A747 or R40 in the tank seems to do the job:)
Post by Eyrey1 on Jun 2, 2015 2:02:49 GMT 1
i use morris castor 2 stroke 5 litres for 45 quid deliverd , castrol 747 , shell racing castor picture of a go cart on the front and a few others , i use them through auto lube and have never had a problem and thats in race rep 250's i get allsorts of wierdo's on big 1000's following me but wont go past me , then at lights they pull up saying fukin hell that smell takes me back mixing one castor with another is ok but do not mix with any other oils ! if you want to use it empty your tank and start again bleed the whole system where can i get this oil and out of the 3 mentioned what would be your preference thanks eyrey1 ..des ebay mate the morris seems the thickest of the oils castrol r30 ,747 and the shell are more runny but i only use my bkes when its warm with castor if you premix in the tank you need to give the bike a shake as it can separate and sink to the bottom in petrol after a week or so but it cant do this using an oil pump each to there own but ive had no problems down to lubrication on my race reps , its your own decision if you use it ,like it was mine when i did ,
Post by kevsypvs on Jun 2, 2015 19:17:08 GMT 1
Castrol r old stock for sale on ebay from America 39 pounds a quart delivered , a tad expensive but very rare
2taol
Post by 2taol on Jun 2, 2015 22:55:58 GMT 1
Anybody used Duckhams QTT ? I used to use it in my LC2 back in the early 90's. Obviously not available any more but i remember it was pricey and it smelled like toffee in the bottle and sweet from the pipe. Cant see any info on the net about it.
Post by arrow on Jun 2, 2015 23:07:43 GMT 1
Anybody used Duckhams QTT ? I used to use it in my LC2 back in the early 90's. Obviously not available any more but i remember it was pricey and it smelled like toffee in the bottle and sweet from the pipe. Cant see any info on the net about it. Duckhams stuff has long since gone. Not seen it around for years.
jools
Post by jools on Jun 3, 2015 4:12:48 GMT 1
As a highly intelligent know it all 17 year old with a new 250B I used to put ordinary castor oil in the tank for that intoxicating "ahh speedway" smell.
then because I knew everything, I drained the oil tank and filled it with R40. The smell was unbelievable, much better than my mates patchouli oil.
months later, after having to have a rebore and rebuild after only a thousand miles or so do to having a clogged & coked up motor and being called a stupid tw#t by my local yam dealer i learnt the error of my ways,,,,,,that will always do it,,,,,,,,maybe I should have used R30 instead. Its not like it was cheaper than Shell 2T or anything.
jools
Post by jools on Jun 3, 2015 5:03:30 GMT 1
Post by The Pirate on Jun 3, 2015 9:49:30 GMT 1
ive heard about putting a spoon of caster oil in the tank for that AHHHHHHHHHH smell,, not sure if they were taking the p155 or not..
Post by davey on Jun 3, 2015 10:29:59 GMT 1
I read somwhere that adding extra oil in the tank when running autolube the engine runs hotter . Apperently its a myth when running in that extra oil in the tank is a good thing again when running a standard autolube system . Just what i read , but stand to be corrected.
castrol r
Jun 3, 2015 11:36:49 GMT 1
via mobile
Post by yazza54 on Jun 3, 2015 11:36:49 GMT 1
I read somwhere that adding extra oil in the tank when running autolube the engine runs hotter . Apperently its a myth when running in that extra oil in the tank is a good thing again when running a standard autolube system . Just what i read , but stand to be corrected. You do need to be careful think of it like this... any oil added in the fuel effectively means that there's less fuel going through the jet so it can make you run weak.
castrol r
Jun 3, 2015 11:38:41 GMT 1
via mobile
Post by yazza54 on Jun 3, 2015 11:38:41 GMT 1
They stopped making Castrol R a long time ago. The equivalent is Power 1 Racing 2T - you can use it with the autolube system and it smells quite lovely That does sound interesting as the stuff I have smells crap but don't really wanna be running old hat castor stuff either From looking it up it's JASO FD too which is the highest spec
Post by kevsypvs on Jun 3, 2015 21:05:45 GMT 1
ive still got some old Castrol r in a tin I bought years ago , use it only in the lawnmower , a small drop added to the petrol ,ahh the memories come flooding back , I even cut the lawn when it doesent need cut lol
castrol r
Jun 13, 2015 22:19:33 GMT 1
via mobile
Post by rossco on Jun 13, 2015 22:19:33 GMT 1
Castor oils like castrol R will not mix with synthetic oils, for gods sake don't put any on top of the remaining oil in your auto lube oil tank. I religiously run castrol A747 on a pre mix basis, (30:1) this gives you that classic 'Castrol R smell' with the modern lubricating properties of synthetic oil. I have been using it for around 5 years, I've just had my 350 engine tuned / rebored / crank rebuilt by graham file and he confirmed this was the best oil to use in LC's / YPVS' if your giving it beans. But do be aware that the A747 has a shelf life (check date on bottle), also if it's mixed with petrol, it will start to loose it lubricating properties after around 3 weeks. It's also susceptible to cold weather, if it's been on your shelf in the garage all winter, bin it.
