Post by LC_BOTT on Sept 8, 2014 14:27:40 GMT 1
Just fitted a spare clutch cable to the resto, and the operation is now awful and hard to pull lever to the bars, is it likely to just be a rubbish cable or the routing (from bars, past clock bracket and through metal 'frame bar' on headstock, (the little wire bracket)
If it's the cable as I suspect, are Norbo's any good, or should I just buy genuine, was ok before the stripdown, from memory, although I only got to ride it once.
Post by lcyoungboy on Sept 8, 2014 16:32:01 GMT 1
Just fitted a spare clutch cable to the resto, and the operation is now awful and hard to pull lever to the bars, is it likely to just be a rubbish cable or the routing (from bars, past clock bracket and through metal 'frame bar' on headstock, (the little wire bracket) If it's the cable as I suspect, are Norbo's any good, or should I just buy genuine, was ok before the stripdown, from memory, although I only got to ride it once. Is it a pattern 1? I fitted a pattern 1 before and the clutch was real hard to pull..also didn't fit the casing properly..got a new genuine 1 and it was perfect again. HTH
Post by bare on Sept 8, 2014 17:17:49 GMT 1
I've found that OEM cables are Excellent. Typically the inner cable falls out when the thing is upended. One from a later Yama model has both ends threaded allowing for easier adjustments and a far more secure grip on the engine case that the old Valvie cable spring clamp.
Post by kostas on Sept 8, 2014 19:09:54 GMT 1
Can anyone post a picture of the gen yam cable as this is fitted at the upper casing?? I have fitted mine but it just dont look right..
Kostas
Post by kostas on Sept 8, 2014 19:11:43 GMT 1
Talking about YPVS engine...
Post by steeley on Sept 8, 2014 19:23:33 GMT 1
Kostas ,some one will be along to give you some help/advice and some pictures.all I have to offer is all the specials I have built myself or for other people I have ended up making my own cables.yes I have made a few.
Post by strat on Sept 8, 2014 20:15:03 GMT 1
Me too, I am having problems with my clutch cable...I think I got it from Wemoto and it's too long and I have had to use a nut for a spacer where I believe there should be an adjuster on top of the crank cases before the clutch operating arm (of which I am missing that retaining clamp weird shaped bit of metal that stops the operating arm from popping up)
Strat.
Post by steeley on Sept 8, 2014 20:29:55 GMT 1
strat ,I had that same sort of trouble years ago the end of the cable would come out of the clutch actuating arm ,bugger.oh a quick fix try a clutch lever adjuster on the crankcase end.
Post by LC_BOTT on Sept 8, 2014 22:07:48 GMT 1
Is it a pattern 1? I fitted a pattern 1 before and the clutch was real hard to pull..also didn't fit the casing properly..got a new genuine 1 and it was perfect again. Yes it was a pattern one, I think the genuine cables have a nylon type inner?? the old one was slightly frayed, so I binned that and found this one as a spare, think this will go the same way. Anyone used Norbo's cables and can comment, £30 for an original makes me choke a little It's on an LC, not YPVS.
Post by midlifecrisisrd on Sept 9, 2014 8:04:13 GMT 1
Me too, I am having problems with my clutch cable...I think I got it from Wemoto and it's too long and I have had to use a nut for a spacer where I believe there should be an adjuster on top of the crank cases before the clutch operating arm (of which I am missing that retaining clamp weird shaped bit of metal that stops the operating arm from popping up) Strat. There is no adjuster on top of the case, just the clip to hold it in place. The problem with a lot of cables (new pattern and old stretched yam ) is the inners are too long so adjustment is difficult. I have a pattern lc2 one on my hybrid which is the correct length but is not Teflon lined so a bit heavier. The 1st cable is shorter due to it having clip ons and has a right angle at the lever end which depending on your lever angle makes it wrong. Early R6 clutch cable fits, is Teflon lined and has a threaded adjuster at the crankcase end that bolts to the cable mount. Steve
Post by midlifecrisisrd on Sept 9, 2014 8:07:59 GMT 1
Is it a pattern 1? I fitted a pattern 1 before and the clutch was real hard to pull..also didn't fit the casing properly..got a new genuine 1 and it was perfect again. Yes it was a pattern one, I think the genuine cables have a nylon type inner?? the old one was slightly frayed, so I binned that and found this one as a spare, think this will go the same way. Anyone used Norbo's cables and can comment, £30 for an original makes me choke a little It's on an LC, not YPVS. Where you finding a gen YPVS cable for £30? Is it an Lc2 one. Ones I see are a little dearer with 20 quid post and the risk of import tax. Lc2 cable is nla from yam but have seen people selling an air cooled cable saying it is the same, any body verify this Steve
Post by strat on Sept 9, 2014 20:15:21 GMT 1
R6 cable, I remember being told this once before now on the old forum, cheers for that Strat.
Post by LC_BOTT on Sept 9, 2014 20:28:24 GMT 1
Post by midlifecrisisrd on Sept 9, 2014 22:37:57 GMT 1
Post by bare on Sept 10, 2014 2:51:57 GMT 1
Yikes! that's a bit Rude ~40 Euros for what seems as an utter crap cable?? OEM or not it's IMO worthless. Just buy a oem Yama R6 one and Never look back.
Post by JonW on Sept 10, 2014 5:06:08 GMT 1
bare, The R6 ones Ive seen (1998/2000/2009) dont have adjustment both ends, what year are you using?
Post by JonW on Sept 10, 2014 5:07:11 GMT 1
Oh and banshee OEM is <$12. short for a 31k, but ok for 85 on Ive been told... anyone confirm?
Post by Tobyjugs on Sept 10, 2014 23:05:44 GMT 1
I visited a bike breakers today and saw an 98 R1 clutch cable today the bottom bit was straight threaded and the top piece was straight with no adjustment. I also bought an FZR 600 cable which was quite a bit shorter and suits the needs of my bike better. Both had made in Japan written on them. What really struck me was the diameter of the actual wire cables i would guess the fzr cable was 30% thicker. They were asking 20 euros for the R1 cable and 15 euros for the FZR cable. (secondhand) I also have not got a clue how it must be fitted but i think it is not so tidy as on an LC.
Post by LC_BOTT on Sept 11, 2014 21:16:06 GMT 1
Post by oldelsieboy on Sept 11, 2014 22:20:10 GMT 1
Or you could go direct to the main dealers and save about a fiver. OEB
Post by Deleted on Sept 12, 2014 1:51:45 GMT 1
I was under the impression Norbo sold them, I would bet my bottom dollar I bought one off him
Post by LC_BOTT on Sept 12, 2014 7:40:49 GMT 1
[quote author=" oldelsieboy" source="/post/247581/thread"Or you could go direct to the main dealers and save about a fiver. OEB[/quote] Cheers, got a few bits/bolts to order, never thought of getting a cable as well for some stupid reason!!!!
cry695
Post by cry695 on Sept 14, 2014 18:28:23 GMT 1
Buy one from yamahabitz. They are genuine and fit perfect See them on eBay.
Post by LC_BOTT on Sept 14, 2014 19:30:51 GMT 1
Buy one from yamahabitz. They are genuine and fit perfect See them on eBay. See the link I put up, it was yamahabitz, and both sold by the look of it.
Post by oldelsieboy on Sept 14, 2014 19:33:32 GMT 1
Buy one from yamahabitz. They are genuine and fit perfect See them on eBay. See the link I put up, it was yamahabitz, and both sold by the look of it. And overpriced OEB
cry695
Post by cry695 on Sept 17, 2014 20:10:26 GMT 1
They have listed 2 today
Post by oldelsieboy on Sept 17, 2014 20:21:16 GMT 1
cry695
Post by cry695 on Sept 17, 2014 20:23:59 GMT 1
R u all tight on this forum ?
Post by strat on Sept 17, 2014 20:35:30 GMT 1
Got an R6 one, adjustable at both ends, shall fit it this weekend......got to be better than my Yambits or Wemoto one.....can't remember who's it was now! Strat.
Post by oldelsieboy on Sept 17, 2014 20:42:51 GMT 1
R u all tight on this forum ? Don't like seeing fellow LC enthusiast getting ripped off. Not all members are as clued up on price & availability of spares. Too many eBay sellers taking advantage listing items as "rare" even tho they are still available from main dealers spares dept, eg: RARE LC indicators priced at £70 a pair which are approx £25 each from Yamaha. OEB
