Post by nigel1967 on Aug 3, 2014 21:27:38 GMT 1
Hi Chaps what's the best way to clean out the rust from tank.
I have some 10mm rounded stones, wrapped the tank in blankets and then securely fitted to a electric cement mixer left it to run for 1/2 hr, then used the rust sealer and proofer prior to flattening the tank back and painting..
Would this work?
Post by raider18 on Aug 3, 2014 21:30:17 GMT 1
salt water & battery charger
Post by grahamv6 on Aug 4, 2014 2:03:29 GMT 1
Salt water and battery charger? How does that work?
Post by stusco on Aug 4, 2014 8:10:27 GMT 1
What do you use for an electrode
Post by raider18 on Aug 4, 2014 15:22:13 GMT 1
I use a threaded bar bit of hosepipe on the bottom & a piece on the top 2 rest against tank live on the tank & earth the rod
Post by stusco on Aug 4, 2014 15:23:42 GMT 1
Thanks might give it a go
Post by steven on Aug 4, 2014 15:35:52 GMT 1
Post by steven on Aug 4, 2014 16:42:41 GMT 1
I use a threaded bar bit of hosepipe on the bottom & a piece on the top 2 rest against tank live on the tank & earth the rod Red to black and blue/blew to fook !!!......... ...I had to check there, its live or RED + on the rod or bar you stick down the filler hole and Black - onto a bare bit of steel on the tank. www.xjcd.org/electrolytic_tank_derustingsteven.
Post by nikfubar on Aug 4, 2014 16:56:32 GMT 1
There ya go, works a treat, soda crystals & water
vazy
Post by vazy on Aug 5, 2014 15:57:27 GMT 1
Bit disappointed, thought the thread was titled Dirty Wank need to upgrade these reading glasses. I'm liking the above idea all the same.
Post by broughton5 on Aug 5, 2014 18:11:57 GMT 1
lol
