Post by supermoto57 on Jun 5, 2019 8:54:19 GMT 1
Post by bodger on Jun 5, 2019 21:27:30 GMT 1
Spent the evening drilling out 3 broken bolts and retapping and redressing threads in my LC frame after having it powder coated, ready to start my rebuild.π₯΅
Post by mellow on Jun 8, 2019 8:49:01 GMT 1
today i'm taking my F2 to the Dyno to get jetting checked. Maybe a power run Hopefully i'll dodge the heavy rain too that we seem to be having
Post by Tobyjugs on Jun 8, 2019 12:59:13 GMT 1
today i'm taking my F2 to the Dyno to get jetting checked. Maybe a power run Hopefully i'll dodge the heavy rain too that we seem to be having Good luck Mellow
Post by mellow on Jun 8, 2019 13:39:00 GMT 1
Well it made 52.3 BHP @ 9862rpm and 28.74Ft.lb @ 8799rpm
Post by tipfinchy on Jun 8, 2019 15:29:32 GMT 1
neil
my 125
Post by neil on Jun 13, 2019 23:40:18 GMT 1
How do you find the damper chap? Can these be fitted onto stock bike?
Post by Tobyjugs on Jun 13, 2019 23:40:19 GMT 1
Fitted a new boot in preparation for the Rotterdam Dirt Sprint. i want to see two RD's in the final.
Post by tipfinchy on Jun 14, 2019 18:46:46 GMT 1
How do you find the damper chap? Can these be fitted onto stock bike? hello Neil , I didn't try it sunday in the end , but will have a run out tomorrow I will let you know , I got it via Brookes suspension its listed as K-tech but made by Toby in Belgium and 140mm stroke so pretty much full lock is available and 25 click adjustment ,NHK ones are 130mm and I think 6 click , as for fitting kits Norbo sells them in the rdlccrazy shop and I think NK racing do them too so they fit a standard bike just get the right size fork clamp and the rad bracket fits all 250/350lc mart
Post by tipfinchy on Jun 14, 2019 18:51:41 GMT 1
Fitted a new boot in preparation for the Rotterdam Dirt Sprint. i want to see two RD's in the final. that looks up for the job , look forward to seeing the pics when is the dirt sprint being held mart
neil
my 125
Post by neil on Jun 14, 2019 20:56:35 GMT 1
Hi mart, thanks ive spoken to Norbo today going to get one from him.
Post by donkeychomp on Jun 14, 2019 22:04:56 GMT 1
Lots.
neil
my 125
Post by neil on Jun 15, 2019 16:44:59 GMT 1
Alex when you say lots were you refering to the steering damper being lots of money? Cheers Neil
Post by badger1 on Jun 15, 2019 17:11:52 GMT 1
Out with a diesel.
Post by marsbar350 on Jun 15, 2019 19:49:36 GMT 1
fantastic picture badge
Post by wonkywheel on Jun 15, 2019 20:39:32 GMT 1
Then it started raining, back to 80s/ 90s youth, great fun
Post by wangwang on Jun 15, 2019 21:01:49 GMT 1
Bought yet more bits, think I need therapy!
Post by badger1 on Jun 15, 2019 21:13:31 GMT 1
fantastic picture badge Thanks my mate took it with just his phone but came out really well
Post by rigga on Jun 15, 2019 21:47:27 GMT 1
Out with a diesel. That LC is mint
Post by donkeychomp on Jun 15, 2019 21:50:53 GMT 1
Alex when you say lots were you refering to the steering damper being lots of money? Cheers Neil Sorry Neil! I meant I did lots yesterday. Dampers can be expensive though, depends on what you want I guess. Got an LC one on my drag bike but I doubt it'll do too much, we shall see! Alex
Post by Tobyjugs on Jun 15, 2019 22:37:57 GMT 1
Fitted a new boot in preparation for the Rotterdam Dirt Sprint. i want to see two RD's in the final. that looks up for the job , look forward to seeing the pics when is the dirt sprint being held mart Hi Mart the event will be on the 13th and 14th of July.
Post by Tobyjugs on Jun 15, 2019 22:39:56 GMT 1
Out with a diesel. Great picture and both bikes like fantastic.
Post by Tobyjugs on Jun 16, 2019 19:53:40 GMT 1
Fitted the back wheel and jetted i bit more lean (close to the edge). Last year it was difficult to keep the front end under control, when it was on the ground, so now I've fitted the steering damper. Also adjusted the gearing as that back wheel is tall. Just got the front wheel to do.
Post by pdxjim on Jun 16, 2019 21:41:30 GMT 1
Fitted new BT45s
Bead refuses to pop out all the way on both tires.
warmed in the sun. 50psi. Lubed to fcuk and malleted to no end.
Ideas?
Post by donkeychomp on Jun 16, 2019 22:15:35 GMT 1
Bike garage? Mine charges a tenner to fit a tyre.
Post by reedpete on Jun 16, 2019 22:21:58 GMT 1
Fitted new BT45s Bead refuses to pop out all the way on both tires. warmed in the sun. 50psi. Lubed to fcuk and malleted to no end.j Ideas? Maybe try top gear artic adventure style....hairspray and a match!
Post by pdxjim on Jun 16, 2019 22:41:06 GMT 1
Fitted new BT45s Bead refuses to pop out all the way on both tires. warmed in the sun. 50psi. Lubed to fcuk and malleted to no end.j Ideas? Maybe try top gear artic adventure style....hairspray and a match! Knowing me, would just make matters worse. ... also, I think that's only with tubeless tires.
Post by pdxjim on Jun 16, 2019 22:44:27 GMT 1
Out with a diesel. Awesome LC Badger! What pipes are they?
Post by badger1 on Jun 17, 2019 6:02:48 GMT 1
Out with a diesel. Awesome LC Badger! What pipes are they? Mutt nuts pipes Norboβs short tz cans
Post by headcoats on Jun 17, 2019 16:22:27 GMT 1
Fitted seals and stainless Pistons into the rear caliper for the Rgv/kr1s rear caliper
Hoses next !
