Post by veg on Jan 12, 2018 17:45:24 GMT 1
Dropped it off at Kimbers for my mechanical anti dive to be made, a new alloy side stand and kickstart and various other small things
Post by mellow on Jan 12, 2018 19:36:35 GMT 1
Nothing it's still in a VAC BAG
Post by andy748 on Jan 14, 2018 0:45:42 GMT 1
Spent 5 hours polishing a set of Allspeeds and painting various bits ready for the rebuild.
Post by 0h5h1t on Jan 14, 2018 20:15:24 GMT 1
serviced front calipers, stripped cleaned and reassembled the speedo drive on my F2 resto. waiting for a goody box from Norbo now
Post by wangwang on Jan 14, 2018 20:59:33 GMT 1
Post by oldelsieboy on Jan 14, 2018 21:13:44 GMT 1
Stripped one engine, now it's time to rebuild another. Make sure you fit the crank seal the correct way round when you rebuild. OEB
Post by wangwang on Jan 14, 2018 21:51:48 GMT 1
There were a few odd things in that engine, but you can see why they got confused....
Post by hudtm60 on Jan 15, 2018 3:33:36 GMT 1
very revealing....tell me: does anyone ever put instant gasket around the bearings?
Post by lrcarl on Jan 15, 2018 10:26:18 GMT 1
very revealing....tell me: does anyone ever put instant gasket around the bearings? Short answer no Carl
Post by brucie on Jan 15, 2018 17:39:33 GMT 1
Took my seat to be recovered
Post by headcoats on Jan 15, 2018 23:17:38 GMT 1
Brushed the dust off my petrol tank on top of the wardrobe
Post by Deleted on Jan 16, 2018 0:24:31 GMT 1
Pulled the oil pump off to see why the left line keeps feeding oil after its turned off. Had a few grains of sand in it. Cleaned them out and still leaking. Oh the pain.
Post by hudtm60 on Jan 16, 2018 18:24:21 GMT 1
ordered a bunch of parts from Norbo. had a delightful chat over tea and biscuits with Annelese from Interparcel. but we all know it's really Bob from Walthamstow. or Ivan from Estonia. o
Post by hudtm60 on Jan 16, 2018 19:59:31 GMT 1
oil pump arrived back from it's hols with Arrow in Cheshire. Looks the business.
Post by Ozhammer on Jan 17, 2018 5:29:10 GMT 1
Fitted my lovely new Motobatt battery, so hopefully my lead acid dramas are now behind me.....
Post by headcoats on Jan 17, 2018 17:50:57 GMT 1
Bought another KR1S wheel, they are like crack cocaine LOL
Post by dazzle on Jan 17, 2018 19:14:06 GMT 1
Took them out of the garage to make room for new table lift, ran them up to temp to keep the juices flowing.
Post by brucie on Jan 18, 2018 13:32:05 GMT 1
Picked my seat up from the shop looks great
Post by 0h5h1t on Jan 18, 2018 17:28:10 GMT 1
Got my goody box from Norbo so have fitted
New rear mudguard New front foot pegs Air filter Clutch and brake levers New springs pins plates etc for rear pegs New handle bar clutch bracket
Mot is looming close now.
Post by hudtm60 on Jan 19, 2018 4:25:16 GMT 1
copied Dusty in the polish dept....and sent them off to PJME for a rebore.....
Post by simon998 on Jan 19, 2018 9:55:42 GMT 1
Sanded back the paint on my 10w swingarm only to discover that some gobshite has isoponed over two big rust holes previously. Then spent the next two hours trying to find my bearings to fit the forks to the frame. Alas I've lost them, that's a £60 mistake.
Post by Tobyjugs on Jan 19, 2018 18:01:14 GMT 1
Just come back from a nice ride
Post by hudtm60 on Jan 19, 2018 19:28:13 GMT 1
in the on-going impulsive, indifference to published advice, somewhat ignorant and partially masochistic quest to remove the 6,000 flat spot from the '81 I purchased a Boost Bottle only to find that things that fit Banshees don't always fit the real motorcycle version- them tubes is too wide. I do my best to ignore the reddevilbodger inside of me- "go on- just drill out them holes on your rare OEM never-touched reed block rubbers with...a big fat drill bit that.....looks big enough" idiot.
Post by Tobyjugs on Jan 19, 2018 22:16:09 GMT 1
in the on-going impulsive, indifference to published advice, somewhat ignorant and partially masochistic quest to remove the 6,000 flat spot from the '81 I purchased a Boost Bottle only to find that things that fit Banshees don't always fit the real motorcycle version- them tubes is too wide. I do my best to ignore the reddevilbodger inside of me- "go on- just drill out them holes on your rare OEM never-touched reed block rubbers with...a big fat drill bit that.....looks big enough" idiot. Buy some banshee rubbers and cut the inner wings off with a very sharp knife/Stanely
Post by andy748 on Jan 19, 2018 22:24:21 GMT 1
Post by copper99 on Jan 20, 2018 14:37:48 GMT 1
You cant talk about your good lady like that! Seriously, good work by the pair of you there..
Post by Mr Kipling on Jan 20, 2018 15:36:34 GMT 1
Installed oil pump n drive gear into the sidecasing..
Post by hudtm60 on Jan 21, 2018 2:15:24 GMT 1
Made a list. .. r
Post by dyrberg123 on Jan 21, 2018 7:34:58 GMT 1
Hi fellows. I spent yesterday on trying to sort out my frame. Bought the bike as a project, but didnt ask seller if the braces where intact - i will never forget to ask about that again. But luckily alot of members have been helpfull so now there could be a solution. Thanks guys
Post by 1601pete on Jan 21, 2018 8:06:32 GMT 1
Cleaned it ready for the Bristol Classis Bike Show
