Post by jon on Jan 21, 2018 9:01:41 GMT 1
in the on-going impulsive, indifference to published advice, somewhat ignorant and partially masochistic quest to remove the 6,000 flat spot from the '81 I purchased a Boost Bottle only to find that things that fit Banshees don't always fit the real motorcycle version- them tubes is too wide. I do my best to ignore the reddevilbodger inside of me- "go on- just drill out them holes on your rare OEM never-touched reed block rubbers with...a big fat drill bit that.....looks big enough" idiot. Don’t do anything to your rubber inlets, or purchase banshee ones as suggested. That boost bottle won’t fit an LC as the tank will hit it. You need one for an LC if your going down that route with the angled sides. Bottom of this page: www.nkracing.co.uk/n4.htmlI’ve got one of these on my LC. Jon
Post by Tobyjugs on Jan 21, 2018 16:08:39 GMT 1
Went for another drive today. Nice sunny morning though a little chilly +2 deg . Kees and me went to the beach via all the small bendy roads and had a real hoot chasing each other. i should set a good example but in the beginning i overtook him and told him he was driving like grandad. We stopped at the beach had something to eat and drink then swapped bikes and drove back like idiots again. Every one bangs on about big bore engines and 350's but i really like the 250 engine. It is sweet as a nut, silky smooth and you can wind it up a treat. I dont think i spent much time below 8000 rpm. The engine noise of those bikes on song got a lot of attention from the public
Post by hudtm60 on Jan 21, 2018 16:51:52 GMT 1
cheers jon. invaluable advice.
Post by dono on Jan 21, 2018 19:03:32 GMT 1
Replaced clock faces and one new needle RDLC, then b.....ks I cracked the glass good and propper! :-( so gutted,has anyone got a spare or an old unserviceable clock I could buy? A very sad Dono
Post by Mr Kipling on Jan 21, 2018 19:12:31 GMT 1
Replaced clock faces and one new needle, then b.....ks I cracked the glass good and propper! :-( so gutted,has anyone got a spare or an old unserviceable clock I could buy? A very sad Dono What bike this for ?? LC ???
Post by dono on Jan 21, 2018 19:15:27 GMT 1
Replaced clock faces and one new needle, then b.....ks I cracked the glass good and propper! :-( so gutted,has anyone got a spare or an old unserviceable clock I could buy? A very sad Dono What bike this for ?? LC Yeah RDLC :-(
Post by Mr Kipling on Jan 21, 2018 19:19:23 GMT 1
What bike this for ?? LC ??? Yeah RDLC :-( if PV Glass is same size I can help..
Post by Mr Kipling on Jan 21, 2018 19:23:48 GMT 1
if PV Glass is same size I can help.. Measure the bevel an give us the size..
Post by stusco on Jan 21, 2018 19:30:13 GMT 1
I don’t think they are the same the lc glass is curved
Post by dono on Jan 21, 2018 19:32:51 GMT 1
if PV Glass is same size I can help.. Ooh I’ve just measured the outside of the case and it’s circa 100mm dia, it’s not the most even of metal work so difficult to be spot on.. do you know what dia the ypvs glass is? Thanks 2scoops, I’ll. keep my fingers crossed. Cheers Dono
Post by Mr Kipling on Jan 21, 2018 19:55:53 GMT 1
if PV Glass is same size I can help.. Ooh I’ve just measured the outside of the case and it’s circa 100mm dia, it’s not the most even of metal work so difficult to be spot on.. do you know what dia the ypvs glass is? Thanks 2scoops, I’ll. keep my fingers crossed. Cheers Dono PV glass quite a bit smaller reckon its around 90 once bevel off.. ???
Post by dono on Jan 21, 2018 20:14:47 GMT 1
Ooh I’ve just measured the outside of the case and it’s circa 100mm dia, it’s not the most even of metal work so difficult to be spot on.. do you know what dia the ypvs glass is? Thanks 2scoops, I’ll. keep my fingers crossed. Cheers Dono PV glass quite a bit smaller reckon its around 90 once bevel off.. Bummer :-( thanks for your help though, really appreciate it. Fingers crossed someone can help.. cheers Dono
Post by wangwang on Jan 21, 2018 20:30:59 GMT 1
PV definitely don't fit. Air cooled ones do and so do XS models.
Post by dono on Jan 21, 2018 21:05:23 GMT 1
Post by wangwang on Jan 21, 2018 21:09:53 GMT 1
Post by wangwang on Jan 21, 2018 21:19:07 GMT 1
I've found an old rev counter, not sure what its from, but appears to be the right size, i'll check and let you know.
Post by dono on Jan 21, 2018 21:30:53 GMT 1
I've found an old rev counter, not sure what its from, but appears to be the right size, i'll check and let you know. Thanks Wangwang, fingers crossed
Post by wangwang on Jan 21, 2018 22:09:34 GMT 1
I've found an old rev counter, not sure what its from, but appears to be the right size, i'll check and let you know. Thanks Wangwang, fingers crossed Good news, it fits, bad news it's 2mm shorter in diameter, but I've tried it in a case and it looks good, PM your email address and i'll send pics.
Post by dave1963 on Jan 27, 2018 17:18:58 GMT 1
Took the ypvs hybrid for mot and it passed slowly getting there. No record on dvla mot history tester said must have been off the road at least 10 years
Post by 0h5h1t on Jan 27, 2018 21:38:19 GMT 1
Nice one Dave mate, you'll soon be hooning around on it then.
Post by 0h5h1t on Jan 27, 2018 21:40:18 GMT 1
Fitted nos unbraced metmachex swinger to the cafe racer.
Post by dave1963 on Jan 27, 2018 21:47:21 GMT 1
Still be trying to keep up with you mate
Post by Jethro5 on Jan 29, 2018 12:02:05 GMT 1
Post by 0h5h1t on Jan 30, 2018 18:04:20 GMT 1
Got my goody box from Norbo so have fitted New rear mudguard New front foot pegs Air filter Clutch and brake levers New springs pins plates etc for rear pegs New handle bar clutch bracket Mot is looming close now. MOT passed today
Post by copper99 on Jan 31, 2018 17:45:57 GMT 1
Picked up my barrels and crankcases from Tony at AJS Aquablasting today, one case was repaired (usual chain damage job) , he's done a top job with all of it, really nice fella to deal with as well.
Post by Haggler on Jan 31, 2018 18:43:42 GMT 1
tidy job copper
Post by midlifecrisisrd on Jan 31, 2018 18:48:06 GMT 1
Cried as I packed it into the new owners van
Laughed at the wad of cash I now have
Post by philmill on Jan 31, 2018 19:04:21 GMT 1
I get the frame all welded and repaired thanks to all for the input, now just sorting RGV bottom yoke. Still cant decide what colour to do the bike, red frame or black. I do like the Kenny Roberts look but quite a few done already.
Post by kostas on Jan 31, 2018 20:03:31 GMT 1
The weld repair looks spot on! Actually it’s almost invisible. I expecting delivery of the olive drab parts from Tony tomorrow.. hoping for similar quality. Kostas
Post by hudtm60 on Feb 1, 2018 22:07:57 GMT 1
Bungs arrived for leakdown. have to make up the copper bits next.
