Post by midlifecrisisrd on Mar 20, 2011 17:56:48 GMT 1
Post by lcowner on Mar 20, 2011 18:21:46 GMT 1
i know wat u mean but the wheels of the xj look very similar but are differeent dunno bout clocks
Post by chris125 on Mar 21, 2011 22:36:58 GMT 1
i got a full lock set of a xj550, and its nearly the same.. i put all the internals in my 4lo lock sets and now hav one key fits all lock set, cost £30 and about 45 mins to change it all around... those internal dials look very close and if there cheap take a gamble !
Post by flames on Mar 22, 2011 5:29:56 GMT 1
i think the xj550's all run a 19" front wheel.so altho the speedo may fit and work,it may be geared differant and give you a false speedo reading.i dont know if you could maybe change the internals for your ones?
Post by midlifecrisisrd on Mar 22, 2011 8:58:47 GMT 1
i think the xj550's all run a 19" front wheel.so altho the speedo may fit and work,it may be geared differant and give you a false speedo reading.i dont know if you could maybe change the internals for your ones? I've looked at a few speedos from 17 and 18 inch wheels. I test them with a cordless drill to see they work, they all read about 37mph which would suggest the difference is in the speedo drive gearing. Steve
