Post by Deleted on Mar 18, 2011 18:53:46 GMT 1
Hi ,i was out on my lc 250 the other day when it started running on 1 cylinder ,i got home and left the bike idling every 3 to 4 seconds the left hand cylinder would fire but now it is gone alto gether ,it has new iridium plugs and the carbs are clean,the battery is not great but lights etc are fine ,help please
Post by gazilla on Mar 18, 2011 22:18:21 GMT 1
I would agree most people recommend the NGK's and pan the Iridium ones.
Post by Deleted on Mar 22, 2011 21:44:55 GMT 1
Started the bike today,the left cylinder has a grey oily substance ot the exhaust outlet and when i rev the bike the exhaust gas is a lot cooler from this exhaust,is this a sign of water getting in to the cylinder.by the way the compression is 90 psi in each cylinder is this low
Post by gazilla on Mar 24, 2011 14:47:36 GMT 1
Check your oil via dipstick.Is that the same grey colour if so this would indicate water in the oil and may be a crank seal gone.
Post by oldelsieboy on Mar 24, 2011 15:08:50 GMT 1
the compression is 90 psi in each cylinder is this low Yes, should be about 120ish. OEB
