Post by exupman on Mar 13, 2011 10:54:11 GMT 1
hello to all you lc nuts! ;D im looking to replace my 250 lc carbs with originals (as mine are mismatched) does anyone have a link ? many many thanks in advance ps love the site ;D when i say links i mean nos or proven replacements cheers
Post by ducatidave on Mar 13, 2011 11:12:28 GMT 1
Don't think ther are nos ones left : (
Post by exupman on Mar 13, 2011 13:06:34 GMT 1
thanks for the response ducatidave , what i meant to ask is, are there any aftermarket carbs for the 250 lc?
Post by exupman on Mar 13, 2011 13:10:21 GMT 1
;D ;D ;D ;D ;D no expense spared ! (within reason!!)
Post by LC'Adam on Mar 13, 2011 13:42:29 GMT 1
Keihin PWK 28's are good Ebay is a good place to look.
Post by twostroker on Mar 13, 2011 15:47:41 GMT 1
31k carbs are a common upgrade for 4lo's so i expect they should be fine on a 4l1 as long as you check the jetting. these are also cheaper than pwk's but as they are over 20 years old now its best to try find a decent pair
Post by exupman on Mar 18, 2011 17:43:25 GMT 1
hello two stroker , what is involved using 31k carbs on a 250 lc ? regarding jetting etc . cheers for a reply btw thanks lc`adam , looked at keihin pwk 28s , but cant find a good retailer that isnt going to rip me off. any suggestions ?
Post by spondonchris on Mar 18, 2011 17:50:28 GMT 1
On a 250 is stick to 250 carbs, plenty show up on gaybay, just make sure they arent German spec which is marked 4L2 they are made slighty diffrently and can reduce power.
Post by daveadams21 on Mar 18, 2011 17:54:08 GMT 1
Post by exupman on Mar 18, 2011 17:59:40 GMT 1
cheers chris ,will use advice,but not gaybay!
Post by bare on Mar 18, 2011 19:50:00 GMT 1
Kawasaki KX85 current model even uses PWK 28's . Currently approx $90 each ..on this side of the Atlantic.. from the Kawa dealers' no less. Seriously suggest NOT buying cheap ass PWK copies.. Just a waste of time/$ and involve serious aggro.. before.. you finally bin them.
Post by daveadams21 on Mar 18, 2011 20:14:32 GMT 1
I think the response about not buying cheap replicas is probably absolutely right. Just a moment of madness. Found Carburettor - Keihin PWK 28mm Flat Slide - on a scooter parts website at £51. Would they work? beedspeed.com/product_info.php?products_id=6751And even if they were suitable could I handle the stick if anyone found out?
Post by 1260dave on Mar 19, 2011 14:15:06 GMT 1
VIN, a member on this forum is selling a good used pair.
