Post by scott on Feb 1, 2007 22:21:39 GMT 1
will apair of rgv 250 (vj22)work on a pv motor i'm gunna be usin pre-mix on me hybrid pv
Post by nuttytart350 on Feb 1, 2007 22:25:23 GMT 1
pair of wot ... pipes / forks / carbs
Post by mellow on Feb 1, 2007 22:26:52 GMT 1
drill a hole n insert brass tube
Post by scott on Feb 1, 2007 22:28:33 GMT 1
shit sorry ;Dthought every 1 would know what i was on about carbs
Post by mellow on Feb 1, 2007 22:34:58 GMT 1
drill a hole n insert brass tube ^^^^^^^^^^^^^
Post by scott on Feb 1, 2007 22:40:22 GMT 1
drill a hole n insert brass tube ^^^^^^^^^^^^^ ???uhh ???praps it's to complicated for me
Post by mellow on Feb 1, 2007 22:42:39 GMT 1
i aint got a clue wot im on about m8..........im sure bare posted elsewhere bout usin other carbs dunno if 250 ones would work............but that was suggestion for oil supply ;D
Post by nuttytart350 on Feb 1, 2007 22:45:16 GMT 1
if u do want oil supply .... then u could also drill the carb rubbers for the feed ... but i am toyin with pre-mix myself ...... yea but no but yea but ...
Post by scott on Feb 1, 2007 22:52:35 GMT 1
i wanna get rid of the oil tank and the air box on mine. i'm sure i've red somewhere that u can use rgv or kr1 carbs
Post by nuttytart350 on Feb 1, 2007 23:02:14 GMT 1
yup ... i got a set of kr1s carbs 2 go ... think norb says the rgv r a little big unless u tune loads
Post by scott on Feb 1, 2007 23:04:54 GMT 1
ok,thanks for that
Post by scott on Feb 4, 2007 22:44:11 GMT 1
ok,do the kr1s carbs go straight on to and work on a pv motor
Post by mellow on Feb 4, 2007 23:28:23 GMT 1
u gotta sort out an oil feed pipe i believe
Post by scott on Feb 5, 2007 0:02:00 GMT 1
even if i'm usin pre-mix
Post by mellow on Feb 5, 2007 10:12:21 GMT 1
erm no ;D
Post by nuttytart350 on Feb 6, 2007 21:31:03 GMT 1
ok,do the kr1s carbs go straight on to and work on a pv motor well u can just squeeze em in on the engine side ... an if u do decide 2 run yur airbox they will even fit in the rubbers that side n all ......
Post by scott on Feb 17, 2007 23:01:16 GMT 1
ok nutty,i've got a question for ya. i've just got a pair of kr1s carbs,and lookin down at the top of em there is a 10-12mm threaded hole to the 1 side of both carbs. what goes in these holes as what ever it is did'nt come with the carbs
Post by nuttytart350 on Feb 17, 2007 23:33:14 GMT 1
ahhh ... thats the choke m8 .... it appears 2 b all in with the cable so god knows wot they cost 2 replace ...
Post by scott on Feb 17, 2007 23:36:34 GMT 1
fook me nutty that was a fast reply ;)fort it was sommat to do wiv the cable,fanks for gettin back to me soooooooo fast ;D u'll av to exuse me i'm slightly intoxycated
Post by nuttytart350 on Feb 17, 2007 23:39:58 GMT 1
yur excused .... ;D
i had 2 reply cos that bully mellow was on at me .... ;D
Post by scott on Feb 17, 2007 23:42:04 GMT 1
thanks nutty ;)so the choke is in with the cable then
Post by nuttytart350 on Feb 17, 2007 23:45:47 GMT 1
well its on a separate cable that goes 2 the handlebar lever ....
Post by scott on Feb 20, 2007 22:39:29 GMT 1
thanks for that wallie
