Post by 1260dave on Mar 1, 2011 2:02:21 GMT 1
Hi Folks Just bought a pair of YPVS reed blocks for a 4LO, Would it be a good idea to use 6mm spacers between the barrels and the reed blocks cheers dave
Post by Norbo on Mar 1, 2011 7:14:29 GMT 1
The ypvs ones are even longer then standard lc blocks so its a must with ypvs blocks in an lc .
Post by 1260dave on Mar 2, 2011 15:04:29 GMT 1
thanks for the info i've bought a few bits and pieces from your shop, cheers for the mega fast and cheap postage ;D
Post by billy on Mar 2, 2011 15:27:41 GMT 1
Yes it's a good idea as the reeds are narrower at the tip then at the bottom, (Hard to explain but maybe you noticed it? Not talking about the obvious "v-shape" but the actual width.) so if you use a spacer, you won't have to widen the inlets quite as much. And believe me, every 10th of a millimeter counts here as YPVS reeds is an extremely tight fit, you don't have any room for a bigger hole cos then you may grind right through the inlet walls.
