m4tt
Post by m4tt on Feb 25, 2011 12:40:20 GMT 1
Hi all,
I am in the process of giving my 1 lady owner f2 a new lease of life and have stripped the top end for a repaint.
It has 30k on the original bore and ran as sweet as a nut prior to the strip with great compression - visually there is very little signs of wear so am now questioning whether to rebore while stripped or just re-assemble?
Whats your thoughts?
Also struggling to get my hands on a replacement set of stainless fairing bolts if anyone has a contact?
Cheers!
Post by lcowner on Feb 25, 2011 14:25:35 GMT 1
imho if theres no wear id leave it prolong the life of ur barrells.can be easily removed and done when needed in future....remember if you rebore u have to run in and me for one would take 5 years to run-in with the mileage i do
Post by twostroker on Feb 25, 2011 14:29:05 GMT 1
best way would be to check the piston/rings/bores tollerences then make a decision......
Post by nikfubar on Feb 25, 2011 16:04:29 GMT 1
If it's in good nick with little sign of wear how about just honing the bores & fit new OEM rings then all it needs is a few heat cycles & it';s as good as new. ;D
Post by lcowner on Feb 25, 2011 16:15:17 GMT 1
If it's in good nick with little sign of wear how about just honing the bores & fit new OEM rings then all it needs is a few heat cycles & it';s as good as new. ;D yeah dats a good idea nik
cooler
Post by cooler on Feb 25, 2011 19:14:59 GMT 1
if it aint broke....saying that i would put new pistons, rings, pins,clips and little ends in ..... but thats just me....
scotty
Post by scotty on Feb 25, 2011 23:40:57 GMT 1
Post by mellow on Feb 26, 2011 13:11:34 GMT 1
ERRRRRMMMM.....OK.....Double post just replied about bolts in your other thread m8
