Post by andygraham on Feb 24, 2011 21:40:28 GMT 1
charged battery plugged everything in got 3 headaches turn indicators on to go left and the right ones start flashing and vice versa side light and clock lights working but no headlight brake light off the rear brake will come on with little pedal pressure.apply a bit more and the light goes out. any ideas chaps
Post by Shytalk on Feb 26, 2011 18:49:41 GMT 1
Indicators : daft question but are they on the correct sides of the bike Headlamp : is fuse OK separate one for headlamp I believe. Rear brake : probably the brake switch either needs adjusting or replacing theres a metal contact that moves down a shaft when you push the pedal that makes contact with another metal area to light the light, so either the contact area is poor or not adjusted well enough.
Post by andygraham on Feb 27, 2011 22:01:06 GMT 1
thanks shytalk one of the possible problems you suggested was right
andy
Post by andygraham on Feb 28, 2011 13:58:18 GMT 1
swapped the wires at the back indies and put a new fuse in for the headlight
Post by Shytalk on Feb 28, 2011 20:08:18 GMT 1
Probably got a spare rear switch if you want to test that too.
