Post by lcowner on Feb 23, 2011 13:18:03 GMT 1
can we put a list of shocks off other modern bikes that are a direct replacment for 4lo,im looking for 1 thats 2" higher than standard-not much to ask now is it?? ;D
Post by lcowner on Feb 23, 2011 20:18:59 GMT 1
does nk racings jack up kit fit the mecthamex shock mount?i know itl fit the bottom of the shock bt wat about the fitment on mecthamex shock mount?
Post by Norbo on Feb 24, 2011 7:20:00 GMT 1
2" is 50mm that will throw the handeling out loads the max you will need is 15mm thats what they race with .
I do have a couple of 15mm prioad and ajustable shiokes in . that are not listed on the site
Post by billy on Feb 24, 2011 9:35:41 GMT 1
In my experience, a shock that is 30 mm longer then stock 4l0 will be too long. The chain will rub against the swinger (even without the swinger protection rubber) when you use the front brake, and the handling will be all wacked. Bike will be all nervous and "weavy" in higher speeds even when going straight forward. (though, a steering damper may help) The 125 shocker seems to be in a much better length. It's 15 mm longer I think.
Post by lcowner on Feb 24, 2011 14:53:25 GMT 1
whats the standard eye to eye on a 4lo shock?really i just want the back end of my lc to look jacked up by about 2'' ,whats the best way of doing this???........
Post by lcowner on Feb 24, 2011 16:20:35 GMT 1
''alter the subframe to tip the tail section up to give it the impression of a raised ass ''
might have a look at this option but is there ajustment here i thought there is just 4 x bolts holding tail on with no ajustment?
