Post by Trubrit on Feb 20, 2011 10:07:45 GMT 1
Hey Guys Just Gettin On With My Build , Couple Of Probably Daft questions .....350lc With F2 Engine & Carbs......Where Does The Middle Pipe On The Pic Below Go .Is It Just A Breather.......And Also What Are The Options For The Extra Water Pipe Coming Off Of The Brass Fitting On The Head......... Cheers Anyone...........
Post by oldelsieboy on Feb 20, 2011 10:23:47 GMT 1
Hey Guys Just Gettin On With My Build , Couple Of Probably Daft questions .....350lc With F2 Engine & Carbs......Where Does The Middle Pipe On The Pic Below Go .Is It Just A Breather.......And Also What Are The Options For The Extra Water Pipe Coming Off Of The Brass Fitting On The Head......... Cheers Anyone........... Extra pipe on carbs is the vacuum pipe which connects to the valvie petrol tap. When used with an LC tank this MUST be blanked off or you will draw in air resulting in a weak mixture. OEB
Post by scott on Feb 20, 2011 10:48:49 GMT 1
as OEB says m8 that needs blanking off and the extra water pipe comin from the pv head,well mine was just blanked off then read somewhere that u should'nt do this so was advised to "T" it into the small hose going from the top of the lc rad to the water expasion bottle
Post by Trubrit on Feb 20, 2011 11:15:11 GMT 1
Cheers guys ...........
Post by wiggy on Feb 20, 2011 13:40:53 GMT 1
i did mine as scott says but it ended up filling the expansion bottle so i drilled a hole in the rad and used an old bicycle valve bolted each side of the rad to hold and connected the pipe as in the pic this is the only pic i have of it done just happens to have the mrs sitting on it
Post by cb250g5 on Feb 20, 2011 22:13:11 GMT 1
I blank the water pipe off & drill a 3mm hole in the thermostat, it's only purpose in life is to allow a little expansion of the water, as it warms up, but before the stat opens.
Post by nikfubar on Feb 20, 2011 22:57:25 GMT 1
i did mine as scott says but it ended up filling the expansion bottle so i drilled a hole in the rad and used an old bicycle valve bolted each side of the rad to hold and connected the pipe as in the pic this is the only pic i have of it done just happens to have the mrs sitting on it Very nice bike aint bad either ;D
Post by lcowner on Feb 22, 2011 12:02:36 GMT 1
niceeeeee........ ;D
