Post by drew1967 on Feb 20, 2011 9:19:24 GMT 1
I've been re-building my 31k engine. While doing the clutch I've noticed that there should be a cushion ring that goes on first. Is this needed. And if it is where I can get one from. Cheers
Post by LC_BOTT on Feb 20, 2011 9:31:32 GMT 1
Some don't bother with any of the rubber dampers, it just makes slightly more noise I think, I did fit mine as they were in good condition and still fitted on dis-assembly. You do mean the ones you fit after each steel clutch plate?
Post by lcowner on Feb 21, 2011 20:58:31 GMT 1
u dont need them i beleive although mine wer there wen i fitted clucth so put them back in .......there suppose to reduce noise but i think its a load o bull
Post by drew1967 on Feb 21, 2011 22:20:13 GMT 1
Cheers lads. Might try without them then. Though there was just one but there is one between each set of plates.
Post by lcowner on Feb 21, 2011 23:37:48 GMT 1
yes i wudent worry bout it m8
