r1olly
Post by r1olly on Feb 17, 2011 17:31:48 GMT 1
hi guys, have recently got a pair of rgv front forks, vj22, ive heard that 1200 bandit calipers fit these. the dimension from centre to centre on both mounting bolts is 90mm, i wiil be running standard discs, can i go for these calipers? i think the early 1200 models for 4 potters, any help would be most gratefull. olly
Post by LC_BOTT on Feb 17, 2011 17:51:25 GMT 1
there are a load of 6 pots that are a direct fit too, (in fact loads of calipers are the same) early GSX-R K1 's etc, some Hayabusa's, the new Bandit 650's, have a look on the RGV site, can't remember the full list, but plenty to choose from.
r1olly
Post by r1olly on Feb 17, 2011 18:00:32 GMT 1
cheers m8 for your help. olly
Post by midlifecrisisrd on Feb 17, 2011 20:56:43 GMT 1
hi guys, have recently got a pair of rgv front forks, vj22, ive heard that 1200 bandit calipers fit these. the dimension from centre to centre on both mounting bolts is 90mm, i wiil be running standard discs, can i go for these calipers? i think the early 1200 models for 4 potters, any help would be most gratefull. olly Had the 4 pot Nissins on my vj22 front end. They were off a GSXR400 but sure they are the same. About to fit the tokico 6 pots. Biggest problem with the nissins is you can't use the rgv lines as they need to have an angled banjo to clear the top mounting bolt. The six pots are ok though. Steve.
r1olly
Post by r1olly on Feb 18, 2011 9:35:47 GMT 1
cheers steve for your help. olly.
Post by rimotu66 on Feb 20, 2011 9:23:42 GMT 1
Ive had loads of problems with Tokiko 6 pots, there a bitch to bleed up and imo they are worse then 4 pots in performance. I changed my old TLR to 4 pots because of this. Just my shillings worth. ;D
r1olly
Post by r1olly on Feb 20, 2011 17:35:46 GMT 1
cheers for your help m8
