paulo
Post by paulo on Feb 15, 2011 0:22:19 GMT 1
Had to split my rear caliper to get the seized pistons out the other day. Cleaned everything up and refitted old seals with rubber grease as everything looked OK, the two caliper half seals didn't look too clever, but cleaned them up the best i could. Tried bleeding it tonight, but seams to be sucking in air from somewhere, can't get a hard pedal . Can you still get the two seals that fit between the two halves of the caliper ?.
Post by mellow on Feb 15, 2011 17:20:41 GMT 1
if u mean the two washers in the middle of the caliper im pretty sure they are just black fibre washers m8
Post by oldelsieboy on Feb 15, 2011 20:16:02 GMT 1
Had to split my rear caliper to get the seized pistons out the other day. Cleaned everything up and refitted old seals with rubber grease as everything looked OK, the two caliper half seals didn't look too clever, but cleaned them up the best i could. Tried bleeding it tonight, but seams to be sucking in air from somewhere, can't get a hard pedal . Can you still get the two seals that fit between the two halves of the caliper ?. Dont think Yamaha ever sold those seals separately but Suzuki do P/N 69107-34200 OEB
paulo
Post by paulo on Feb 15, 2011 22:25:39 GMT 1
Thank you O "Wise Ones" for your guidance. Young "Grasshopper" has much to learn about the world of the "LC". Will re-strip, but this time without 6 cans of John Smith's washing around in my stomach. Going to look at the bleed nipple too, as it had to be locked off fairly tight before it stopped the flow - thinking about it now, if it was the half seals, i would expect fluid weeping out, or was that just me when i couldn't get a pedal. Next step re-strip and inspect again - cheers chaps.
Post by mellow on Feb 15, 2011 22:30:52 GMT 1
dont talk to me about bleed nipples m8
paulo
Post by paulo on Feb 15, 2011 22:32:59 GMT 1
Why mate, have you had problems in the past ?.
Post by mellow on Feb 15, 2011 22:38:23 GMT 1
got it now lol.see my 125 rebuild thread I hate bloody motorbikes ;D
Post by mellow on Feb 16, 2011 22:55:51 GMT 1
yeah next time ur ill take ur pc to bed with ya.....HOW DARE YOU GO OFF WORK ILL!!! ;D
Post by mellow on Feb 16, 2011 23:13:06 GMT 1
so am i right assuming the above suzuki part number for the seals fits the yamaha calipers then
paulo
Post by paulo on Feb 17, 2011 22:36:38 GMT 1
Hi Mellow, i have every faith in oldelsieboy, just ordered two up (just over £2 quid each) & piston seals too - whats another £15 - be cheaper restoring a Rolls Royce ;D. Will let you know for deafo when bits arrive .
Post by mellow on Feb 17, 2011 23:26:18 GMT 1
where from i looked them up n they was £8 ish
paulo
Post by paulo on Feb 18, 2011 21:53:16 GMT 1
Post by mellow on Feb 18, 2011 21:58:54 GMT 1
them ebay ones are £3.50 m8
paulo
Post by paulo on Feb 18, 2011 22:05:07 GMT 1
sorry mate , thought it was for x2 , better stop searching the web and drinking at the same time, or is it just down to old age ;D
Post by mellow on Feb 18, 2011 22:06:13 GMT 1
OLD AGE M8 LOL ;D
paulo
Post by paulo on Feb 19, 2011 22:19:36 GMT 1
Well stripped my caliper down and the new seals are too small . new ones are 11.5mm O/D, 6.5mm I/D & 2.2mm thick. LC11 early type rear caliper type are 13.5mm O/D, 8.5mm I/D & 2.2mm thick. Maybe the Suzuki P/N oldelsieboy gave are for the later type caliper . Cleaned everything up and again and re-assembled and have now got a pedal , a little spongy, but I'm hoping thats down to the new pads and disc .
