Post by alext on Feb 14, 2011 20:53:51 GMT 1
what is the general consensus on Microns v's Allspeeds??
I have both (lucky me) - the microns are in very good condition, the allspeeds will need a bit of work.
is there much between them - I was led to believe the Microns will put the power higher up the range, the Allspeeds being better at low-mid rpm.
Ta
Post by mellow on Feb 14, 2011 20:57:47 GMT 1
yeah thats about it m8
Post by lovelydog on Feb 14, 2011 21:31:23 GMT 1
I prefer the sound of Microns but reckon Allspeeds are safer, Microns are good for putting holes in your pistons though.
Post by Norbo on Feb 14, 2011 21:48:53 GMT 1
I can see this being a very visated post with lots of replys by the end of the week .
Speeds look better but give no extra power and bike dont rev with them on . Crons do give extra powe a bike will be faster with them on but are a bitch to jet . Well ther were back in the day but nowa days with all of you lot helping people there realy is no exquse for fusking up jetting . Just ask for help .
So its looks or power realy .
Post by alext on Feb 14, 2011 22:48:19 GMT 1
ok, so........
can anyone recomend somewhere that will rechrome exhausts??
(I know most places dont want to do this)
paulo
Post by paulo on Feb 15, 2011 0:25:09 GMT 1
Power for me any day
Post by mellow on Feb 15, 2011 1:01:43 GMT 1
Post by bare on Feb 15, 2011 3:58:00 GMT 1
it's been MY experience that Microns (at least) Do Not require rejetting from yama stock to run perfectly Need to rejet is an old wives' tale. Unless you somehow dick with the quantity of air going INTO an engine (Filters / Airbox /Porting.. there should not be any need to re-jet... Cuz the fuel/air mixture has not been changed !
Post by alext on Feb 16, 2011 18:03:46 GMT 1
They are made of 2 pressed steel parts welded
I'll get pictures when I return home - in London seeing the sights right now
Post by bare on Feb 16, 2011 18:42:38 GMT 1
They all are :-) Quite short silencer cans (bean can) types were the earliest (?) ones, earliest of those (condor made?) had a wee flared exit from the bean can end, slightly later ones simply had no tube beyond the end of the can end plate. Noise is an issue with either.
Post by alext on Feb 21, 2011 20:13:00 GMT 1
they are short-can no outlet pipe.
noisy??
I like that!
