Post by lcowner on Feb 7, 2011 22:21:07 GMT 1
normally 1 or 2 kicks an bike starts.today whent to start it to let it run for a while but wudent attempt to turn over . checked was i getting spark and that was ok.... took carbs apart as i thought 1 of the jets was blocked but they wer fiine.... only thing was that i changed the position of bars/throttle and it wasent ticking over right as the cable was jamming the slides open ect but i have the throttle flicking really nice now with good action and is closing and opening slides as t shud... any suggestions do i bump start it to clear it maybe?when the weather clears up here
Post by johnlc on Feb 7, 2011 22:30:15 GMT 1
Are the float valves ok and the fuel tap ok too
Post by lcowner on Feb 7, 2011 22:35:37 GMT 1
u mean the floats themselves ?had a bit of trouble with fuel pissing outa the lhs carb but wen i stripped carbs everythhing looked ok.maybe i 'l strip them again and have a look.....
Post by 1260dave on Feb 8, 2011 2:47:35 GMT 1
sounds like you need to check your float heights
Post by johnlc on Feb 8, 2011 9:23:53 GMT 1
u mean the floats themselves ?had a bit of trouble with fuel pissing outa the lhs carb but wen i stripped carbs everythhing looked ok.maybe i 'l strip them again and have a look..... Sorry i meant the float needles probably some crap in there but i bet the tap is leaking internally ,had exactly the same happen to me
Post by lcowner on Feb 8, 2011 9:48:05 GMT 1
sounds like you need to check your float heights right after a bit of reading about i think i need to set my float heights!i was playing around with the floats when i cleaned carbs out hence fuel pissing oua overflow so i probably bent the 'tang' on float a bit.soooooooooooo whats the fools(thats me!) proof way of doing this right?
Post by 1260dave on Feb 8, 2011 11:38:56 GMT 1
undo the single screw on the bottom of the float bowl, somehow jam a piece of clear tube in the threaded hole, pass the tube up the side of the carb fill the carb with petrol the fuel should travel up the pipe to within +/- 1mm of the float bowl gasket face, i had the same crack with mine
Post by LC_BOTT on Feb 8, 2011 12:53:08 GMT 1
undo the single screw on the bottom of the float bowl, somehow jam a piece of clear tube in the threaded hole, This is probably the most accurate way, but you can just connect the pipe to the overflow outlet, its not required, and as you leave the drain screw undone, will be at the same level as the petrol in the bowl?
Post by lcowner on Feb 8, 2011 14:31:01 GMT 1
il have a go at this in a while ad report back,thanx chaps
Post by lcowner on Feb 8, 2011 15:47:20 GMT 1
all sorted now second kick and into life!set float heights.thanx for all ur help
Post by mellow on Feb 8, 2011 17:20:53 GMT 1
glad to hear that.i was just gonna suggest givin it a good kickin ;D
Post by johnlc on Feb 8, 2011 17:21:41 GMT 1
Glad to hear you got it fixed
Post by lcowner on Feb 8, 2011 18:08:09 GMT 1
thanx chaps ,feel like burning it somedays!
