nola
Post by nola on Jan 28, 2011 19:17:56 GMT 1
hey guys im stripping an 87rz...for the motor gonna part out the rest....i wanna put the valve in my lc and was wondering what i should keep from the rz....if anything besides motor of course..i need to use the rz wiring correct? .....i was thinking of buying new electronics off norbo as i dont know the condition of the donor bike stuff.....what exactly will i need...does the valve bolt right into the lc frame....any and all advice highly welcomed!..Cheers Neil.... Attachments:
Post by LC_BOTT on Jan 28, 2011 19:51:41 GMT 1
Can't you keep everything until you've finished? be a lot easier if you find you need something, rather than having to buy or scrounge it from someone knowing you had it all along? you'll probably need most things that plug into the loom, PV motor etc Oh yeah, engine is a straight swap
Post by soccersmyth on Jan 28, 2011 21:37:43 GMT 1
If you'r gonna strip the engine for inspection/clean/etc. Consider buying another set of crankcases to use in the rebuild if the frame and cases of the RZ have matching numbers as you will get a good price for the frame and cases with matching numbers. And as your gonna be puting the rz engine into a 4L1 4L0 frame the numbers will not match anyway.
Good luck with the project.
