Post by andygraham on Jan 27, 2011 22:45:35 GMT 1
side panels and tail piece what are the best ways to repair the stress cracks in them?
Post by scott on Jan 27, 2011 22:49:30 GMT 1
just put this up for headcoats,i have used this stuff called Q-BOND and found it really good m8 item number..280429032480,can't get the link to work . i tried the soldering iron trick and it kept on re-cracking so tried this and is stiil fine.
Post by andygraham on Jan 27, 2011 22:55:35 GMT 1
ok scott ebay number? will take a look thanks
Post by andygraham on Jan 27, 2011 23:00:29 GMT 1
looks just the job scott do you just cover the crack or is it best to cut down the crack line and fill it that way it should never reappear
Post by scott on Jan 27, 2011 23:25:20 GMT 1
looks just the job scott do you just cover the crack or is it best to cut down the crack line and fill it that way it should never reappear yes m8 best to open up the crack a bit and do it that way m8.
Post by mellow on Jan 27, 2011 23:26:35 GMT 1
Post by scott on Jan 27, 2011 23:30:17 GMT 1
Post by mellow on Jan 27, 2011 23:33:54 GMT 1
easy ;D
Post by andygraham on Jan 27, 2011 23:38:07 GMT 1
10000 plus posts! plenty of practice......
Post by twostroker on Jan 27, 2011 23:57:21 GMT 1
looks just the job scott do you just cover the crack or is it best to cut down the crack line and fill it that way it should never reappear yes m8 best to open up the crack a bit and do it that way m8. this kit works great ive used it a number of times but its very important to remove all paint from the repair area and make sure there is no grease,dirt or dust present.
