Post by scott on Jan 26, 2011 21:36:33 GMT 1
i was on the A/C forum a while ago but went on 1 time and i could'nt sign in it anymore,anyways can someone on here tell me the bore size of A/C 400 barrels as i've checked mine and they measure 64mm which would make it the same as an rd 350cc bike,the piston is identical to a pv piston :-/i'm thinkin the barrels have been relined,the lining is about 5mm thick and 1 is slightly twisted off line.the barrels do have 398cc on the side of em tho. i've checked because i wandered if i could get a pair of overbored 350lc barrels relined to take the 400 pistons,anyone know if this can be done aswell.
Post by oldelsieboy on Jan 26, 2011 22:33:00 GMT 1
i was on the A/C forum a while ago but went on 1 time and i could'nt sign in it anymore,anyways can someone on here tell me the bore size of A/C 400 barrels as i've checked mine and they measure 64mm which would make it the same as an rd 350cc bike,the piston is identical to a pv piston :-/i'm thinkin the barrels have been relined,the lining is about 5mm thick and 1 is slightly twisted off line.the barrels do have 398cc on the side of em tho. i've checked because i wandered if i could get a pair of overbored 350lc barrels relined to take the 400 pistons,anyone know if this can be done aswell. RD400 A/C bore size is 64mm same as 350LC but the stroke was longer giving it the extra few cc's HTH OEB
Post by scott on Jan 26, 2011 22:38:11 GMT 1
i was on the A/C forum a while ago but went on 1 time and i could'nt sign in it anymore,anyways can someone on here tell me the bore size of A/C 400 barrels as i've checked mine and they measure 64mm which would make it the same as an rd 350cc bike,the piston is identical to a pv piston :-/i'm thinkin the barrels have been relined,the lining is about 5mm thick and 1 is slightly twisted off line.the barrels do have 398cc on the side of em tho. i've checked because i wandered if i could get a pair of overbored 350lc barrels relined to take the 400 pistons,anyone know if this can be done aswell. RD400 A/C bore size is 64mm same as 350LC but the stroke was longer giving it the extra few cc's HTH OEB ok m8 thanks for that,was abit worried bout it tbh.av some karma
Post by Norbo on Jan 27, 2011 7:30:23 GMT 1
Thery use YPVS pistons mate just a longer rod thats all .
Post by scott on Jan 27, 2011 22:27:19 GMT 1
Thery use YPVS pistons mate just a longer rod thats all . ok thanks m8, i was abit worried about em being same bore size as 350cc so just glad thats cleared up.
