Post by carlow73 on Jan 26, 2011 18:45:46 GMT 1
hi , i just bought a nice rd 125 mk2 , very clean . only one small problem it smokes a lot , the fellow i bought it off said it has been sat in his garage for 17 years , it looks like it has, no rust what so ever but it smokes a lot . i tried adjusting the 2stroke pump but still smokes , when you rev it it smokes but when you shut it off it smokes a lot more , i was told maybe its seals gone , does anyone know what the problem mite be . cheers colin
Post by carlow73 on Jan 26, 2011 20:08:56 GMT 1
cheers jazz , i bought the bike as a mon runner , got it home changed the bottom end oil and 2stroke ,filled her up and it started 4th or 5th kick , it came with a standard pipe and a mint allspeed but smokes the same from both pipes
Post by tout on Jan 26, 2011 20:36:09 GMT 1
Its when they dont smoke you need to be concerned ;D
Post by carlow73 on Jan 27, 2011 18:38:54 GMT 1
cheers gary thanks a lot ill pm you if i need to , thanks colin
Post by carlos on Jan 29, 2011 13:37:14 GMT 1
Mine smokes the first time you give it lots of throttle but then clears up lovely!
Let us know what you find!
Post by billy on Feb 12, 2011 14:50:47 GMT 1
cheers jazz , i bought the bike as a mon runner , got it home changed the bottom end oil and 2stroke ,filled her up and it started 4th or 5th kick , it came with a standard pipe and a mint allspeed but smokes the same from both pipes Wait, wot? The 125's only have one pipe as they have single cylinder engines. You sure you didn't buy a 250 or 350 LC? ;D Edit: Oh now I see what you mean about the pipes lol, should have read it more carefully. ;D
