Post by alext on Jan 26, 2011 11:57:56 GMT 1
does anyone know the maximum I can offset the chain-run by on a 4L0 without having to modify the frame in any way?
Im fitting an FZR400 rear-wheel (140 section tyre on a 4 inch rim).
its looking like there wont be too much juggling to get it in amazingly! (if my initial measurments were nearly right)
ALex.
Post by oldelsieboy on Jan 26, 2011 12:02:37 GMT 1
does anyone know the maximum I can offset the chain-run by on a 4L0 without having to modify the frame in any way? Im fitting an FZR400 rear-wheel (140 section tyre on a 4 inch rim). its looking like there wont be too much juggling to get it in amazingly! (if my initial measurments were nearly right) ALex. Fitted to my 4L0 I have a 140/70 x 17" tyre on a 3.5" wide rear wheel with a 9mm offset front sprocket so you should not have too many probs. OEB
Post by lcowner on Jan 26, 2011 14:21:16 GMT 1
what does offset mean?and what is the pupose of it?
Post by nikfubar on Jan 26, 2011 15:46:34 GMT 1
what does offset mean?and what is the pupose of it? If you fit a wider rear wheel it moves the chain out so your front & rear sprockets won't line up so you fit a offset sprocket to correct this. Talon make these in various different offsets This one I'm fitting to my hybrid is 6mm offset.
Post by lcowner on Jan 26, 2011 16:35:40 GMT 1
thanx nik wondered wat it was cheers,so its a bit like putting a spacer behind the sproket to bring it out......... silly me
