Post by Trubrit on Jan 25, 2011 19:04:56 GMT 1
Got The Sprockets On My Hybrid Im Doing , Whats The Best Method Of Measuring The Offset For The Front Sprocket .........
Cheers Anyone..................
Post by willieeckerslike on Jan 25, 2011 19:11:13 GMT 1
Ring Nigel Kimber at NK Racing, he will give you instruction on how it's done.
He explained it to me but I cannot remember what he told me but it was easy
Bleedin short term memory is awful, 25 years of smoking possibly to blame
W
Post by Trubrit on Jan 25, 2011 20:13:23 GMT 1
Cheers Gaz That makes sense...............
Post by nikfubar on Jan 25, 2011 20:29:05 GMT 1
place a tube or rod against the side of the sprocket at the rear so it lies 100%flat...then make that rod gointo the gear sprocket...then measure the distance from the tube side to the sprocket face on gear shaft....thats about it i am told...that distance is then say may be x amount so then that is the distance required...i am sure that what i was told how to do it. +1 just make sure the wheel is perfectly alined though or you could be miles off. ;D
