Post by andygraham on Jan 25, 2011 12:23:35 GMT 1
I've just stripped both engine cases.was told that pj1 satin was the colour to use.having sprayed the clutch cover it looks really dull.would a lacquer coat on top improve the finish? Should I use a different paint maybe gloss pj1?
Post by nikfubar on Jan 25, 2011 17:36:22 GMT 1
PJ1 gloss ;D
Post by lcowner on Jan 25, 2011 18:00:25 GMT 1
if u put a coat of larquar on top of the satin youve done it will be shiney same as gloss m8
Post by andygraham on Jan 25, 2011 18:27:16 GMT 1
thanks guys will swop me matt for gloss then or maybe leave as is.matt black is the new white seen beckhams matt black porsche for sale?
Post by midlifecrisisrd on Jan 25, 2011 20:32:40 GMT 1
I've just stripped both engine cases.was told that pj1 satin was the colour to use.having sprayed the clutch cover it looks really dull.would a lacquer coat on top improve the finish? Should I use a different paint maybe gloss pj1? The satin stuff is quite matt unless you bake it to cure it, usually gave it an hour or 2 to go touch dry then pop it in the oven and slowly increase the temp every 10 mins. Would not go too hot if it's a plastic ypvs one. Steve.
Post by andygraham on Jan 27, 2011 22:53:40 GMT 1
hi guys used the pj1 gloss in the end havent got the best of finishes everything was nice and warm but the finish seems a bit blotchy i didnt use a primer.could that be the problem also the imperfections in the casings are showing thru maybe another can of paint will do the trick
