Post by graham198 on Jan 24, 2011 19:38:26 GMT 1
hi ive just noticed that ive got a leak in my tanks at the bottom on the side i cant see any holes and fuel is slowley coming out whats the best way to solve this apart from a new tank lol cheers
Post by winnerevo1 on Jan 24, 2011 20:56:13 GMT 1
POR15 should do the trick, been in one of my tanks for over 5 years and no probs.
DON'T USE PETSEAL! ;D
Post by scott on Jan 24, 2011 22:35:36 GMT 1
Post by scott on Jan 24, 2011 22:44:02 GMT 1
Thats a work of art scott seen it a few times your work on this tank and i'm more impressed the more i see it ;D ;D well i'd got nuffin to lose m8 as tank was well holed so thought i'd give it a try and so far so good,it helped with having the speed block to mask up to aswell tho.just the yellow that reacted with sommat that lets it down :-/not fussy tho me m8 ;D
Post by LC_BOTT on Jan 25, 2011 9:43:21 GMT 1
That's a very nice job on the tank soldering, what did you use, a proper powder or jelly flux, never could get it to stick when I tried once, got a guy at work to fit a new plate in mine in the end, was at the bottom of a 3MA tank where the fuel tap sits.
Post by lcowner on Jan 25, 2011 11:23:57 GMT 1
i threw out an lc tank wen i started my rebuild,whish i hadent now after seeing this ...........it wasent even that bad few holes n bottom
Post by scott on Jan 25, 2011 21:29:58 GMT 1
That's a very nice job on the tank soldering, what did you use, a proper powder or jelly flux, never could get it to stick when I tried once, got a guy at work to fit a new plate in mine in the end, was at the bottom of a 3MA tank where the fuel tap sits. the solder was the leaded type none of this ozone friendly stuff and the flux was a plumbers jelly flux
