jonno
Post by jonno on Jun 26, 2006 7:34:40 GMT 1
I am thinking about upgrading the front forks on my LC for a pair of F2 forks.
What yolks do i use?
Will the F2 rear wheel fit into the standard LC swingarm & what modifications are required?
Thanks in advance.
Post by wiggy on Jun 26, 2006 10:09:23 GMT 1
you will need f2 bottom yoke (stantions are thicker) goes straight in 4l0 frame and then depending on which clocks you use you may have to change top yoke or get the standard lc one machined out to take the f2 stantions not sure about the rear wheel though i do think it goes in but you will need to mod rear brake system
jonno
Post by jonno on Jun 26, 2006 13:15:02 GMT 1
Thanks wiggy,
I am intending on converting the rear brake to disc anyway.
jonno
Post by jonno on Jun 26, 2006 13:17:36 GMT 1
Thanks for that dirtbag.
