Post by Oliver31 on Jan 18, 2011 8:23:04 GMT 1
Guys,
Noticed when the rear wheel is in place there is play in the rear sprocket , is this normal.You can lift the rear sporcket not by much but there is some play. Do I need new cush drive rubbers or can anyone suggest something to stop the movement. I thought about packing the rubber cush drives.
Post by lovelydog on Jan 18, 2011 8:50:17 GMT 1
Mine was the same on both 250 and 350lc, I lived with it as it never felt slack enough to be dangerous,but replacement is available and probably best for £40.
Post by lcowner on Jan 18, 2011 10:40:15 GMT 1
mine had a bit of play in tem but when i got the wheel powdercoated it was fine
Post by zxr59 on Jan 18, 2011 13:53:25 GMT 1
i bought a zxr 750 a few years ago and they were packed out with strips cut from an old inner tube, ran it for nearly 3 years like this with no problems but if you really want peace of mind best to replace them.
Post by jonahlc on Jan 18, 2011 19:06:57 GMT 1
mine the same been like for about a year with no problems. ought to change them though
Post by lovelydog on Jan 18, 2011 21:05:07 GMT 1
Thinking of my last post,my 250 had 350 rear wheel fitted after previous owner put original under a car. Got a feeling that the 250 didn't have cush drive......pretty sure.
