Post by chippy28 on Jan 16, 2011 12:40:32 GMT 1
Hi All,can anyone tell me if the front caliper bolts are still available from Yamaha for a 250lc?,been to my local nut and bolt shop and they have nothing that will do the job.
Cheers,Andy.
Post by oldelsieboy on Jan 16, 2011 13:00:38 GMT 1
Hi All,can anyone tell me if the front caliper bolts are still available from Yamaha for a 250lc?,been to my local nut and bolt shop and they have nothing that will do the job. Cheers,Andy. Yes they are still available from Yamaha but are different to the original design. Original were fitted with plain & spring washers, superseded items are flange headed. If you want a couple & are not too concerned about the finish I have plenty you can have FOC. OEB
Post by chippy28 on Jan 16, 2011 14:04:15 GMT 1
Thankyou OEB for the offer but the reason I want to change mine is because they are original and the chrome is flakey and naff looking. Thankyou too gary,will go for the new ones then.
Cheers,Andy.
Post by LC_BOTT on Jan 16, 2011 14:46:05 GMT 1
Post by chippy28 on Jan 16, 2011 17:11:24 GMT 1
Thankyou LC_BOTT
Post by tout on Jan 16, 2011 17:16:57 GMT 1
Just to amuse many, I sent a set of originals away to be rechromed The W**K -Shaft only polished the numbers off the top..didn`t he not best chuffed
Post by greenlandy on Jan 16, 2011 19:51:07 GMT 1
I think you need to change your nut and bolt shop! They should stock a metric fine high tensile bolt.
Post by chippy28 on Jan 17, 2011 16:46:26 GMT 1
I think you need to change your nut and bolt shop! They should stock a metric fine high tensile bolt. They did have some but the shank lengths were all wrong and they only had them in black un treated,other than that can`t fault the shop at all. Anyways orderd two from Fowlers at about £2 ish each. Cheers,Andy.
