dwyermcalaster
ye cant bait the smell of 2 stroke
carbs
Jan 11, 2011 18:21:47 GMT 1
Post by dwyermcalaster on Jan 11, 2011 18:21:47 GMT 1
well lads have put new carb repair kit in a couple of times worked fine for while then floats seem to get stuck and petrol comes out of over flow what would cause this
carbs
Jan 11, 2011 19:58:49 GMT 1
Post by greenlandy on Jan 11, 2011 19:58:49 GMT 1
what kit did you use?
dwyermcalaster
carbs
Jan 11, 2011 20:13:58 GMT 1
Post by dwyermcalaster on Jan 11, 2011 20:13:58 GMT 1
bought them on ebay mate not sure of make would 2 stroke mixture be 2 rich
carbs
Jan 11, 2011 20:34:38 GMT 1
Post by greenlandy on Jan 11, 2011 20:34:38 GMT 1
probably a shit kit to be honest. 2 stroke mixture is set by the oil pump not carb, fuel air mixture is done by carb. TBH I'm not a carb expert but it's more likely the needle valve not seating, stopping the fuel flow rather than the float sticking. HTH Matt
dwyermcalaster
carbs
Jan 11, 2011 20:39:33 GMT 1
Post by dwyermcalaster on Jan 11, 2011 20:39:33 GMT 1
probably a shit kit to be honest. 2 stroke mixture is set by the oil pump not carb, fuel air mixture is done by carb. TBH I'm not a carb expert but it's more likely the needle valve not seating, stopping the fuel flow rather than the float sticking. HTH Matt thanks for info mate very annoying for them to stick the whole time and be leaking
carbs
Jan 11, 2011 21:26:22 GMT 1
Post by greenlandy on Jan 11, 2011 21:26:22 GMT 1
Norbo only sells kit that he recommends best to drop him a PM or email. He's a good guy helped me no end on Xmas eve when I was spinning out over a Loom I'd got from him.
