Post by greenlandy on Jan 9, 2011 20:28:09 GMT 1
Post by winnerevo1 on Jan 9, 2011 21:38:08 GMT 1
Have you re-torqued the head after first heat cycle? You could re-torque it a touch higher and see if it cures.
Are your bores much over size? If they are your head gasket bore might be a bit on the small side.
You could try a touch of sealant.
Genuine head gasket may do the trick but a good quality pattern one should be ok.
I would try those before paying someone to look at them.
Failing that, ensure head is flat and both barrels th same height.
Post by greenlandy on Jan 9, 2011 22:15:50 GMT 1
Yeah re-torqued head was thinking of doing it again just as a last resort. Bores are 1mm over. Head seems to be flat not got an engineers surface plate to check for certain though. Used Norbo's Quality ones was wondering if a copper one would do the trick?
Post by johnlc on Jan 9, 2011 22:20:58 GMT 1
I checked my head on the living room window for warpage before lol
Post by mellow on Jan 9, 2011 23:10:20 GMT 1
i used a genuine gasket and it weeped on front edge in middle took it back off n put a "smidgin" of sealer on...sorted
Post by nikfubar on Jan 10, 2011 0:58:54 GMT 1
Try re-torquing the head before you do anything else, mine started blowing coolant out the expansion bottle second time out, re-torqued and was ok for a few rides then did it again after a severe thrashing. Re-torqued a bit higher & it's been fine for the last year
Post by greenlandy on Jan 10, 2011 21:26:37 GMT 1
I'm away this week but will warm her up and retorque later in the week. If it leaks again I might resort to sealant but have never needed to on any other engine. Can you O'ring a 4L1? If so how much? On another note at what age does a bike have to have indicators? Thinking of throwing it into an MOT if I can later this week.
Post by greenlandy on Jan 11, 2011 19:40:39 GMT 1
Thanks Gary
