Post by drew1967 on Jan 5, 2011 22:33:50 GMT 1
paulo
Post by paulo on Jan 6, 2011 21:54:29 GMT 1
Drew, how i normally do it - is to fill with oil then removal surplus with a syringe until you get the required air gap from the top of stanchion to oil level - Haynes states 195mm +/-5.5mm - as far as i know this is correct, but someone else maybe able to confirm !.
Post by drew1967 on Jan 7, 2011 0:02:18 GMT 1
That's what I think I'll do Paulo. But will take quite a bit more oil than stated in Haynes. Would the leg be extended or pushed down?
Post by Tone on Jan 7, 2011 7:19:08 GMT 1
To check oil level/air gap remember that it is checked with the fork spring removed and the stanchion pushed right down inside the leg and measured from top of stanchion. Tone
Post by drew1967 on Jan 7, 2011 8:56:58 GMT 1
Tone. That adds another variation because I'm sure in Haynes it says measure it with spring in.
Post by Tone on Jan 7, 2011 13:48:19 GMT 1
Just had a look in the Genuine Yamaha Workshop manual for my LC2 and it says Fork oil level: From top of inner tube fully compressed Without spring. Tony
paulo
Post by paulo on Jan 7, 2011 20:44:43 GMT 1
Drew, i have always done it as Tone has stated, spring removed then stanchion fully depressed - pump the stanchion a couple of times also to circulate the oil through the lower leg if the forks have been totally stripped and cleaned of oil. Dug out my LC Haynes manual, your right it tells you to fill / measure after fitting the spring, but my LC2 / YPVS Haynes tell you to fill / measure with spring removed / depressed fully and fork leg held vertical - this makes more sense and also when the spring is fitted, it normally sits proud to the top of the stanchion, so would make measuring difficult - hope I'm right, as thats how I've just re-filled my LC2 legs.
