Post by Trubrit on Jan 4, 2011 22:00:43 GMT 1
Anybody got any options on what switchgear i could use on my hybrid besides the Obvious LC Or PV ones ...........Cheers.......................
Post by nikfubar on Jan 4, 2011 22:35:52 GMT 1
ou can use anything that takes your fancy although the R/H switchgear should be from a 2 stroke otherwise you will have a redundant electric start switch. I've used RGV switch gear on my last build, you can see it in the Vapor thread below. On the one I am building now I've used Aprilia RSVR L/H switches & KR1s R/H switches
Post by soccersmyth on Jan 4, 2011 22:35:58 GMT 1
I've seen it on here but cannot find the link.
Rgv ones wired into the LC/PV's bar switch's plug work and you have choke on bar too if you change your choke plunger on carb.
Post by nikfubar on Jan 4, 2011 22:38:28 GMT 1
I've seen it on here but cannot find the link. Rgv ones wired into the LC/PV's bar switch's plug work and you have choke on bar too if you change your choke plunger on carb. Yeah it's on mine ;D check it out in reply to your Vapor question.
Post by soccersmyth on Jan 4, 2011 23:30:07 GMT 1
Weird. i replied to this when no replies showing. Then i check back and a reply at the exact same time. doo doo doodoo
