paulo
Post by paulo on Jan 2, 2011 21:28:45 GMT 1
Hi all, just about to start refuring my 5/8 front brake master cylinder for my LC / YPVS rebuild. Just a couple of questions please ;D Is this a common cylinder fitted to both the LC 350 and LC2 It's just before i order the bits from Norbo, want to make sure i get the right ones. Also going to pop it in the bench blasting cabinet, whats it like getting the viewing glass out - is it going to be more trouble that its worth - ie do they leak afterwards Cheers Paul. Will hopefully post a new rebuild thread as soon as the wife replaces the 4th broken camera in the last 6 months - I'm sure i would get off with it .
paulo
Post by paulo on Jan 3, 2011 20:25:35 GMT 1
Was thinking around those lines too, but can't afford the original Yam one mate, but could stretch to the pattern one with the F2 type brake switch fitted - suppose you just make up a fly lead to connect direct into the LC loom.
Post by bare on Jan 5, 2011 19:51:43 GMT 1
Don't Bother! Buy/use the LC250 1/2" bore master cylinder. Yes! it's a serious improvement.
paulo
Post by paulo on Jan 5, 2011 20:43:45 GMT 1
Cheers for that bare, something else to consider, and they cost a lot less - like it . So the brakes if fitted to a 350 would be improved ?.
Post by winnerevo1 on Jan 5, 2011 23:10:22 GMT 1
No, well not in outright braking performance/stopping distances/fade etc.
It will make it feel different, whether you prefer the feel is another story altogether.
Post by Shytalk on Jan 6, 2011 14:27:27 GMT 1
Cheers for that bare, something else to consider, and they cost a lot less - like it . So the brakes if fitted to a 350 would be improved ?. Depends really on the state of the existing M/C and lines, you can use the lower spec 1/2 in M/C and replace the front lines for braided, you can refurb the one you have, I wouldn't blast a M/C personally I would nitromors it by hand and spray with PJ1 from a rattle can but if the sight glass is cloudy then I'd probably do as Gaz suggests and pop a new non Yam one in, I think a M/C refurb kit is £25 plus the time taken to prep and spray etc, swings and roundabouts in the end.
paulo
Post by paulo on Jan 6, 2011 21:36:41 GMT 1
Cheers for all the input chaps, mentioned by master cylinder problem at work earlier this week to a couple of work colleagues and a chap from another part of the factory phoned me up today about a 5/8 Yamaha pattern cylinder thats he's had lying around in his shed for a year of too - couple of slight chips in the paintwork here and there, but apart from that, as good as new - £15 and the deal was done. I'm a very happy chap, i think with the money I've saved i may go for a nice polished top off Norbo .
