Post by aaronben40 on Dec 26, 2010 21:45:24 GMT 1
Does anyome know the part no for the 4L0/4L1 temp sensor?
Cheers
Post by oldelsieboy on Dec 26, 2010 21:59:25 GMT 1
Does anyome know the part no for the 4L0/4L1 temp sensor? Cheers Item number 26, not cheap tho' OEB
Post by nikfubar on Dec 26, 2010 23:10:50 GMT 1
Is it the same as one for an F2 as I've got one you can have it you need it ;D
Post by jonahlc on Dec 27, 2010 11:07:12 GMT 1
had same problem made up a short spade to bullet connector wire so didnt have to chop up origonal loom
Post by winnerevo1 on Dec 27, 2010 11:08:00 GMT 1
Am I correct in thinking that the thread is different on some/all YPVS heads compared to LC?
I'd heard that but don't know if it's correct.
Post by nikfubar on Dec 27, 2010 12:12:08 GMT 1
Pretty sure all YPVS heads are M10 x 0.75 taper thread which is standard for most Yamaha's. I'm fitting R1 clocks to mine & the R1 temp sender has the same size thread Looking at the diagram above it looks as if the sender unit may have a different thread as there is a sealing washer below but if it's the same size you are welcome to the spare one I have, I can make you an adaptor as well.
Post by elsie1411 on Dec 27, 2010 12:15:34 GMT 1
seem to remember pv has a tapered thread where the lc has a straight thread and uses a sealing washer
Post by winnerevo1 on Dec 27, 2010 12:41:56 GMT 1
seem to remember pv has a tapered thread where the lc has a straight thread and uses a sealing washer Yes, That's what I was reffering to but have read conflicting views on forums and not having a YPVS, have never been able to confirm.
