Post by watchhislegs on Dec 19, 2010 20:06:05 GMT 1
I'm full of questions today; anyone got any suggestions on how to mount a single round headlight to a set of Aprilia RS125 forks. I'm sure plenty have done it with RGV front ends and they are probably a similar diameter fork leg.
I'm going to be running a set of N2 clocks but I'm pretty sure I'll be able to bracket them onto the ignition mounts on the top yoke as I've done this before.
Your help would be appreciated
Thanks
Nico
Post by nikfubar on Dec 19, 2010 21:02:17 GMT 1
You could make brackets for mounting the headlight which are fixed to the top & bottom yokes.
Post by watchhislegs on Dec 20, 2010 21:19:40 GMT 1
Looks mint that mate, only problem with mine is the bolts ar on the back side of both yokes. I'm going to have to have a bracket off the mid-point of the fork leg between the yokes I think. Just out of interest what did you make the bracket out of?
Post by nikfubar on Dec 20, 2010 21:24:28 GMT 1
Post by watchhislegs on Dec 22, 2010 0:18:24 GMT 1
Cheers fella, looks interesting. Your RD is looking amazing by the way. Swingarm conversion looks really clean and the rest of it is something else. Top work.
Post by nikfubar on Dec 22, 2010 21:41:13 GMT 1
Cheers matey ;D that mobile phone your buildings gonna be You & me are the only ones on the forum with single sided swingers, I think Here's a tip for ya, I think the only thing that ruins the look of the swing arm is the ugly chain guard with the rear brake line on top. I've run the brake line inside the arm so I can do away with the chain guard & achieve this look.
Post by trev1340 on Dec 22, 2010 23:23:45 GMT 1
that looks the nuts nik any chance of a pic of the other side ?
Post by nikfubar on Dec 23, 2010 1:35:27 GMT 1
There you go fella, it's not mine by the way wish it was
Post by watchhislegs on Dec 28, 2010 16:55:16 GMT 1
Looks good mate! Might have to get down B&Q when the sale madness has subsided.
Post by JonW on Dec 29, 2010 1:55:27 GMT 1
Nik, this image with those brackets makes me nod and smile every time i see it. Superb work, looks factory!
