Post by tout on Dec 16, 2010 20:45:02 GMT 1
Maybe an anorak moment the blocks have a wee rectangular tab cast in the body The best pics show them both pointing towards the fuel tap side ! is this correct ? look identical bar the tab.. another question,I have found some fibre reeds one side solid,one side 2 stage...which way up ? just curious as using stock steel petals T
Post by tout on Dec 16, 2010 21:26:59 GMT 1
Well theres a few alternatives for sure,all acceptable Anyone have the link for pics of Kevs bikes in his living room. ? Ok dont laugh...haynes shows both towards the petty tap need this detail bang on......you know what its like gaz when some c**k pulls you up on a miniscule blemish
Post by oldelsieboy on Dec 16, 2010 21:31:35 GMT 1
Anyone have the link for pics of Kevs bikes in his living room. ? Ok dont laugh...haynes shows both towards the petty tap So does Kevs www.skills.plus.com/ref/index2.htmOEB
Post by tout on Dec 16, 2010 21:39:59 GMT 1
Again...top man Nigel Thanks pal for once haynes is bang-on
Post by greenlandy on Dec 17, 2010 20:28:17 GMT 1
both outward's...they are for removal of the blocks when they stick to the gasket....make's sence if on outside...tab is so a driver/drift can be used to tap them off the barrels. used them today for this very purpose
btlc
Post by btlc on Dec 20, 2010 20:07:15 GMT 1
I bought a 250lc this summer thats been stored since 1982 with 5020 miles and is 100% original, when i removed the carbs for cleaning i noticed the tabs your talking about where both facing to the left (petrol tap side) at the time i thought the same as gary-rd-robbo that it would have made better sense to have them both to outside to help removal.
Post by tout on Dec 20, 2010 23:48:37 GMT 1
btlc sounds like you have a original unmollested bike tabs correct direction too
I have a LC with them both pointy outy.....however one under current build is both to the left !
Post by winnerevo1 on Dec 21, 2010 20:52:10 GMT 1
lc was a cobbled together bike painted shite and with wonky decals from factory...i doubt mr mitsui ever thought these bike's would last this long let alone cause great debate 30 years down the line... ;D ;D ;D gaz I'd say you're probably right and I'd bet he'd have a fit at some of the prices of parts! ;D
