Post by chrismac on Jan 23, 2006 14:30:00 GMT 1
Any ideas how to stop the kick start swinging out? It seems very loose and maybe the cut out for the ball bearing looks a little worn. Is the any answer a new one?
Post by Norbo on Jan 23, 2006 18:34:38 GMT 1
Take it apart and remove the spring under the baring, grip the spring with plyers in the wire cuting bit and keep doing this all the way up the spring . This will make it biger then refit and greese it put the baring on top and see how it is . you may allso need to add a thin wosher to the top befor the C clip .
Post by chrismac on Jan 25, 2006 21:52:14 GMT 1
Cheers Norbo, the spring thing worked all nice and tight now
