Post by chippy28 on Dec 3, 2010 21:43:46 GMT 1
Hi All,on a 250lc should I be able to see the oil pump plunger moving in and out when I operate the kickstart?because I am getting close to starting my rebuild and want to be sure the pump is working as it should.
Thanks in advance,Cheers Andy.
Post by nikfubar on Dec 3, 2010 22:10:04 GMT 1
It takes a lot of revolutions to make the plunger move in and out so very little movement using the kick start. When I first started mine I used a temporary fuel tank with premix. An old RD oil tank, hanging on fence. This way you can check and adjust pump etc plus it makes it easier to get at things with no tank fitted.
Post by chippy28 on Dec 4, 2010 21:35:09 GMT 1
Thankyou chaps,will rig up a tank then and run on premix till I am sure.
Cheers,Andy.
Post by chippy28 on Dec 5, 2010 13:36:59 GMT 1
Thankyou gary,will do as you suggest.
Cheers,Andy.
Post by chippy28 on Jan 21, 2011 18:40:50 GMT 1
Hi All,the bike is running now and the pump is working as it should but how the F**K do you stop the engine when the rod of the pump is out at its most travel to check the gap with a feeler,any tips most welcome.
Cheers,Andy.
Post by chippy28 on Jan 21, 2011 21:03:28 GMT 1
Thanks Gaz,will try again tomorrow.
Cheers,Andy.
