k&n's
Nov 29, 2010 12:48:10 GMT 1
Post by Oliver31 on Nov 29, 2010 12:48:10 GMT 1
After some advice, my set up is a a w reg rd350LC engine Mick Abbey heavily ported motor, running v force reeds and a skimmed head. Standard carb set up, lomas pipes. My question is I have in my garage a set of k&n's which have a rubber tube then inserted is a metal tube connected to the k&n.
It moved the k&n approx 6-7cm from the end of the carbs.
what is this for,will they work on this engine or should i revert to std airbox or ramairs. want to get the best performance.
r1olly
k&n's
Nov 29, 2010 16:56:20 GMT 1
Post by r1olly on Nov 29, 2010 16:56:20 GMT 1
id go for ram air mate k and n will bog the the power down, especially with a tuned motor. olly.
k&n's
Dec 3, 2010 15:51:56 GMT 1
Post by tout on Dec 3, 2010 15:51:56 GMT 1
Sounds like a recipe for crank munching..... put the K+N`s on ebay.........put the proceeds aside for a future rebuild
