Post by soccersmyth on Nov 22, 2010 17:12:16 GMT 1
I will be fitting a 31k motor into a 4L0 frame witha RGV banana arm and wheel.
I have been told that the front sprocket offset to align straight to the rear sprocket is not the same on the 31k and 4L0 motor.
What do i need to do to get it aligned ?
Post by billbott on Nov 22, 2010 20:58:06 GMT 1
Post by tout on Dec 3, 2010 20:06:14 GMT 1
yeh, sounds daft but they are all different
Post by tout on Dec 4, 2010 14:20:48 GMT 1
The first bit of advice,is to make sure of wheel allignment You cant rely on the chain pull markings on the swinger alone Use trammels or a laser pointer to determine front to rear wheel allignment,, if you are using track-scrub tyres make sure you do multiple checks on various points about the wheel once satisfied..have a look at the chain pull markings for general reference... Ok then back to the initial ask...check final drive allignment
