Post by lcowner on Nov 15, 2010 23:44:56 GMT 1
anybody know if there is a special tool for ajusting the eccentric ajusters on the mecthamax swingarm?? have it fitted no problems but just to ajust the the chain i think theres a special tool for this and if there is wer can i get ?? ;D
cheers lco
Post by lcowner on Nov 16, 2010 0:46:19 GMT 1
have emailed them headcoats thannx, but wondered if anyone on here knows...........
Post by JonW on Nov 16, 2010 4:09:00 GMT 1
With the same type of adjusters on the KTM duke you use a large allen key in the adjuster as a lever to move it to where you want it. Im not saying yours are exactly the same, as i dont know, but the theory is probably right.
Post by Norbo on Nov 17, 2010 7:19:29 GMT 1
You just need to loosed the 2 allen key bolts boths sides . ajust it back with a socket and tighten the allen keys back up then lock the nut down simple . It ajusts the both sides at the same time .
jonno
Post by jonno on Nov 17, 2010 8:59:14 GMT 1
As Norbo says.
r1olly
Post by r1olly on Nov 17, 2010 9:02:35 GMT 1
hi, i used to have one of those swing arm yrs ago,,,,,i just made a tool up.
Post by lcowner on Nov 17, 2010 11:02:40 GMT 1
ok chaps thanx
jonno
Post by jonno on Nov 21, 2010 14:32:48 GMT 1
When i fitted my metmachex to my lc, i noticed that the brace of the arm was hitting the lower inner plastic mudguard and making a noise. For the sake of sanity i cut a nodule out of the plastic mudguard and the noise stopped. Also my chain seems to be sawing its way through the front of the swingarm and rattles against it quite a bit.
Has anyone else had this problem with a fitted metmachex, or do i need to go to weight watchers? ;D
