dwyermcalaster
ye cant bait the smell of 2 stroke
Post by dwyermcalaster on Nov 12, 2010 22:08:14 GMT 1
hi lads can any one help when my sump bolt is tightend up its still letting oil out around it a bit tried few washers still happening if i tighten any tighter starts to loosen help please
Post by looey on Nov 12, 2010 22:11:32 GMT 1
Sounds like the thread has stripped on the plug or in the sump if it loosens when you tighted it more ? .
dwyermcalaster
Post by dwyermcalaster on Nov 12, 2010 22:15:50 GMT 1
Sounds like the thread has stripped on the plug or in the sump if it loosens when you tighted it more ? . i think so mate what can i do tightens an awfull way up before starts to loosen what can i do please help
Post by looey on Nov 12, 2010 22:24:08 GMT 1
Well if it's the plug you need a new plug, if it's the sump then you need to get the thread helicoiled or drilled and re-tapped the next size up !!!. You could as a temporary measure try and wrap the plug with a little ptfe tape. It can be a little trial and error with the amount of ptfe tape, too much and it'll be too tight to screw in, too little and it'll still feel a little loose and won't seal. The correct amount should make the plug just tight enough in the thread to screw right in and stop the oil even getting to the plug washer. Done it a few times over the years myself but only as a temporary measure . Who said bodger !!!! ;D
Post by gazilla on Nov 12, 2010 22:25:51 GMT 1
If you mean that when tightened it then loosens the thread sounds knackered and will need heli coiling.You can do this youself.Find out the thread size and pitch (did have quick look but could not find)then you can get set from e bay or Uni thread (in Motorcycle mechanics) or take to good motorcycle shop for repair.
dwyermcalaster
Post by dwyermcalaster on Nov 12, 2010 22:34:01 GMT 1
cheers lads this is not on my rd its on another bike . new to servicen them .have is screwed up all the way and seems to go up fine on proper tread just at very end when trying to get tight it starts to loosen its one with screw in bolt,
Post by looey on Nov 12, 2010 22:42:43 GMT 1
cheers lads this is not on my rd its on another bike . new to servicen them .have is screwed up all the way and seems to go up fine on proper tread just at very end when trying to get tight it starts to loosen its one with screw in bolt, Yep, that's exactly what happens when the thread is knackered .
dwyermcalaster
Post by dwyermcalaster on Nov 12, 2010 22:44:31 GMT 1
cheers lads this is not on my rd its on another bike . new to servicen them .have is screwed up all the way and seems to go up fine on proper tread just at very end when trying to get tight it starts to loosen its one with screw in bolt, Yep, that's exactly what happens when the thread is knackered . if i got smaller bolt would this help
Post by winnerevo1 on Nov 12, 2010 22:47:27 GMT 1
no mate.
dwyermcalaster
Post by dwyermcalaster on Nov 12, 2010 22:51:42 GMT 1
more washers i just would not know enough to redrill or any thing like that am only learning thanks all
Post by winnerevo1 on Nov 12, 2010 22:56:20 GMT 1
Better off taking it to a competent mechanical type. If you are really not sure of the concept you could make matters worse.
Better to play it safe.
