Post by case on Nov 5, 2010 20:06:57 GMT 1
dont know whats up but when i try to pull bike backwards it seems like the front brakes are dragging help appreciated ;D
Post by JonW on Nov 7, 2010 8:33:17 GMT 1
id like that link too if you have it
Post by Shytalk on Nov 7, 2010 11:14:26 GMT 1
Post by JonW on Nov 7, 2010 23:12:00 GMT 1
Cool, cheers. Lovely work by Gaz of course.
Post by case on Nov 8, 2010 21:34:43 GMT 1
I will have to pull them apart again then, ive replaced the seals and what not so i must have missed something, it rolls forward fine and brakes well and releases fully its just when im manouvering backwards its like trying to pull a jcb ??
Post by dredge3 on Nov 9, 2010 23:33:08 GMT 1
I will have to pull them apart again then, ive replaced the seals and what not so i must have missed something, it rolls forward fine and brakes well and releases fully its just when im manouvering backwards its like trying to pull a jcb ?? Same here mate. I stripped the lot. Pistons free, copper grease etc. Only thing I found was loads of shims. I think the calliper twists a bit when pushed backwards. Havnt had a good look. Funny, if I tap calliper with mallet, all is ok.Which sounds like sticking piston, but it isnt
Post by bare on Nov 14, 2010 20:47:04 GMT 1
Make sure the wee almost invisible hole in the floor of the Master Cyl reservoir is clear (use a bit of copper wire strand)
